I've got a set of those and they struggle at the best of times. At the front of the engine, no chance.
I take it you've tried mole grips on it?
Rounded Bolt - Replacing Cam Position sensor on 3.0
- smorris_12
Scott
Where are we going and why am I in this handbasket?
2006 Z4 2.5si Silbergrau und rot
Scott
- nblu
Thanks everyone. I have finally managed it after getting a decent quality set of pliers. Everything else I tired wouldn’t bite. I should have invested in them sooner.
Thanks,
Nick
Lesson learned. Thanks,
Nick
Current - Blue 2009 E89 sDrive 3.0, Sports Seats, Cruise Control and turbine alloys
- smorris_12
That's a lifetime pair. Knipex make some serious gear.
Glad it's sorted!
Glad it's sorted!
Scott
Scott
- nblu
Thanks, I thought it was the last thing to try before giving in and letting a professional look at it. For £27 it was much better than the cheap Draper set I had tried.smorris_12 wrote: ↑Mon Apr 17, 2023 6:40 pm That's a lifetime pair. Knipex make some serious gear.
Glad it's sorted!
In case it is useful to others the new parts cleared my fault codes. I was getting 2aa0 intake cam position, 2aa1 exhaust cam position and 29ce misfire cylinder 2. The first two codes were fixed by the cam position sensors. The 29ce was fixed by replacing the ignition coil which was a very straightforward job.
The car is off to the MOT centre today, wish me luck...
Thanks,
Nick
- nblu
Just a quick update, the car is back on the road. It failed its first mot on emissions as another coil pack was causing a misfire. Retest after replacing that pack and it’s all clean.
Looks like I’ll be looking at new rear shocks next as mine are corroded. I’ll be digging around the forums for recommendations next
Thanks,
Nick
Thanks,
Nick
I needed a Frequency Inverters and I spent ages searching for one online. Eventually, I was pointed in the direction of asb-drives.eu. All their components can be found easily, and I liked the intuitive design of the website. On top of that, I was impressed with the speed and quality of the service, so I can confidently recommend the site.
- colb
If you had tried that bolt with an extractor socket before you mullered it to death I reckon it would have broke free. My recent exdperience with a stuck and rounded off Lambda Sensor was similar to your journey. Had to break off the top of the sensor to get the extractor socket on but it worked to crack off the sensor thread on the second pull with the breaker bar atteched to the socket. I now have two sets of extractor sockets in the toolbox small up to 19mm and a larger set that are sold as wheel nut removers, the 22mm in that set was used on the lambda sensor. Now if I come across any ruted seized in bolts these sockets will be the first way to go.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
Coil packs i would just replace the lot. I did at 80k miles.
My colleagues car lost a coil at 12k miles.
