s54 Valve cover gasket recommendations
- alane29
Hello
Planning on replacing the valve cover gasket as its seeping a little , Any recommendations for the gasket OEM or another make
2007 E86 M Coupe
2005 E85 2.5SE
2005 E85 2.5SE
OE Orginal. I have used ElRing and it leaked shortly after. Same for the fastener grommets. the clamping of the fastener against the grommet is what makes the seal. and you can reuse the original one a couple of times too.
- alane29
I had been looking at a Victor Reinz set comes with gaskets & gromets for £51 , will price the BMW one .Not bothered about saving money just want the one that does the job
2007 E86 M Coupe
2005 E85 2.5SE
2005 E85 2.5SE
Yes, you will regret if you find a leak and have to do it all over. that was my case.
- XMetal
Agreed. I ran into the same issue with the Elring gasket/grommets and eventually have to redo it with the OE gasket and grommets. Just go OE and be done.
- Beedub
ive got an el-ring set in the shop but ive always gone O.E due to being told they leak. Not something i want to deal with..... do you guys use alittle sealant around the half moons at the back ?
Funny thing, I did with the elring one, however it did not leak from there but from the area above the exhaust cam sensor, I even try and apply sealant there and it did not work, i was even worrying the issue was my aluminum cam cover had warped. Then I read in E46 forums how many had had issues with aftermarket ones.
With the OE one I used nothing anywhere and has been leak free for 2 years.
- Beedub
does the oe gasket set now days come as a kit including the spark plug gaskets, cam cover bolt grommets , and the washers for the oil drain? i cant actually remember as its been so long since i ordered one, i need to get a new set ready for the valve adjustment this year.
Some companies such as ECS, FCP, etc have put kits together, but if you buy from the Dealer, you need to pice out your kit (gasket, grommets, spark plug gaskets, etc.
- grannyknot
Whether you go with aftermarket or OEM be sure to follow BMW's torquing sequence specs, off the top of my head it is done in 3 steps, each progressively tighter.
2008 E86 M coupe
Toronto, Ontario
Toronto, Ontario
I still have the same Victor Reinz gasket for 50k+ miles and have had the valve cover off at least 5 or 6 times in those miles. Usually, I'll apply fresh Drei-bond to the half-moons in the rear and where the VANOS meets the cylinder head every other time the cover comes off. It stays leak free other than some light sweating which is pretty typical especially if you don't wash the engine bay.
It is surprising to hear that multiple people have had issues with the Elring gasket. They make the head gasket, oil pan gasket, VANOS gasket and a few other S54 gaskets for BMW.
- R60BBA
It’s not the gasket which is the issue, it’s their not so great packaging.Slideways wrote: ↑Tue Feb 28, 2023 7:54 am I still have the same Victor Reinz gasket for 50k+ miles and have had the valve cover off at least 5 or 6 times in those miles. Usually, I'll apply fresh Drei-bond to the half-moons in the rear and where the VANOS meets the cylinder head every other time the cover comes off. It stays leak free other than some light sweating which is pretty typical especially if you don't wash the engine bay.
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- colb
Always fit Elring cam cover gaskets set which includes the sealing washers for the cover retaining bolts (15) and have done a few replacements now without any issues. On the 2.5 BMW TIS instructions say to use gasket sealant only around the half moon shapes at the front and rear of the cover where the gasket changes direction and between the Vanos at the front. I use Blue Hylomar for the sealant which is good enough for Rolls Royce and Areo engines so ok for the Z. If you look at the bolts on the 2.5 they have a shoulder on them so when tightened up that shoulder contacts the metal of the head compressing the gasket against it and the ribbed seals around the gasket as well as the round rubber seals. Do not overtighten the bolts you run the risk of snapping them.
Cylinder head cover to cylinder head Size M6 Torque to 11 Nm.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
- R60BBA
Different engine mate.colb wrote: ↑Wed May 15, 2024 8:19 am Always fit Elring cam cover gaskets set which includes the sealing washers for the cover retaining bolts (15) and have done a few replacements now without any issues. On the 2.5 BMW TIS instructions say to use gasket sealant only around the half moon shapes at the front and rear of the cover where the gasket changes direction and between the Vanos at the front. I use Blue Hylomar for the sealant which is good enough for Rolls Royce and Areo engines so ok for the Z. If you look at the bolts on the 2.5 they have a shoulder on them so when tightened up that shoulder contacts the metal of the head compressing the gasket against it and the ribbed seals around the gasket as well as the round rubber seals. Do not overtighten the bolts you run the risk of snapping them.
