Z4m engine mounts
"M" Specific discussion
mmm-five
Z4m engine mounts
Post by mmm-five » Fri Jan 13, 2023 7:40 pm
maupineda wrote: Fri Jan 13, 2023 3:38 am VT fail prematurely. I have them and they are coming out in a week. I am using 034MS mounts. Btw, the VT mounts vibrate bad at idle, plastic rattles and visible vibration of the steering wheel. I had to rise idle to 950 rpm to mask the rattling at idle.
How prematurely?
Mine have been on for over 8 years (62,000 miles) of what I'd call 'leisurely' driving.
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
XMetal
Z4m engine mounts
Post by XMetal » Fri Jan 13, 2023 7:54 pm
I had the VT mounts on my car for about 7 years and 30k miles, when they were starting to show signs of wear with small cracks in the rubber. I've seen someone with similar issue and their mounts just suddenly fail soon after. I love the VT mounts, but the slight increase in NVH at idle was starting to bother me a bit. With that said, I don't quite like the spongy feel of the OE mounts, but had considered going back to OE. Ultimately, I took a gamble on the 034MS mounts and can vouch that they have the OE feel at idle and none of the spongy feel of the OE mounts when loaded - a great middle ground! I also liked that the 034MS mounts isn't fluid filled, so it won't fail/collapse like the OE will inevitably do soon after (the 034MS mount is essentially a solid version of the OE mount with the fluids being replaced with all rubbers). This is a win-win in my book :driving:
FYI - I did paired the 034MS motor mounts with the RE transmission mounts, as did with the VT.
XMetal
Z4m engine mounts
Post by XMetal » Fri Jan 13, 2023 8:01 pm
I have a suspicion that you will like the 034MS mounts. It won't be as stiff as the VT mounts, but not as soft and spongy as the OE either. NVH will be eliminated (at least for me) at idle.
maupineda
Z4m engine mounts
Post by maupineda » Sat Jan 14, 2023 12:25 am
Look up for VT on M3s and you will see there are more reports than me. A few from Z4Ms also.
Harshness is the least of the issue. As I said, a few more idle rpms cure it. But when the cracked after 3-4 years and 20k kms… and as expensive as they are… they are no good IMO. I will post photos for you to see.
maupineda
Z4m engine mounts
Post by maupineda » Sat Jan 14, 2023 12:28 am
XMetal wrote: Fri Jan 13, 2023 8:01 pm
They are in a bin ready to go in about a week 👌
beanie
Z4m engine mounts
Post by beanie » Sat Jan 14, 2023 12:22 pm
I didn’t notice any extra nvh with VT mounts and rogue engineering gearbox mounts.
Tbh, I’d happily go for something stiffer next time around, at least from an nvh perspective.
RUBYIMOLACARBON
Simon 3.2M
Z4m engine mounts
Post by Simon 3.2M » Sat Jan 14, 2023 2:17 pm
I’m happy for people to try the race mounts if they like - that are just sat in the garage doing not a great deal.
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Wassup
Z4m engine mounts
Post by Wassup » Thu Jan 19, 2023 2:33 am
These came fitted to my Z4MC and were causing major vibrations at idle, the whole interior was shaking as if at 6 on the Richter scale. Once on the move, no vibrations at all and needless to say I changed them for OEM mounts and all is well once more :D
2008 Z4MR Ruby Black, Sepang Hell, Carbon Weave
2006 Z4 3.0si Montego Blue, Imola/Black individual
NCS/ISTA diagnostics & coding in Midlands - pm me
maupineda
Z4m engine mounts
Post by maupineda » Thu Jan 19, 2023 11:37 pm
^^ exactly my case, my mounts are cracked and the car vibrated noticeably at 870rpm idle. it is fine at 970 - 1k rpm idle. again, the issue not idle speed, I actually prefer a higher idle to keep good oil pressure, the issue is them cracking so soon. those that have them should go and check closely, I never noticed cracks until I removed the aluminum shield to clean it, then was able to see the rubber is dry and cracked, though a bit less than the above
maupineda
Z4m engine mounts
Post by maupineda » Mon Jan 23, 2023 8:17 pm
I replaced my mounts this weekend, went with 034MS mounts, very nice, much smoother vs VT, and the shifting is equally good, at least in street conditions. even cranking the engine for startup, and engine shut-off is smoother. and you save 60grams if that matters
Old mounts (20k kms and 4 years). Rubber is cracking
New 034MS Mount
XMetal
Z4m engine mounts
Post by XMetal » Tue Jan 24, 2023 7:17 am
^^ Good to hear your positive results with the 034MS mounts and confirmation of my impression of them as you're only the 2nd person (other than myself) that I know of that are using them on the E85/E86 platform. I was made aware of the 034MS mounts on the E46M3 forum.
My VT street mounts looked pretty much like yours when I took them off and swap them for the 034MS about 1.5yrs ago. It didn't occurred to me to weigh them...so thank you for that info :thumbsup:
InterlagosMC
Z4m engine mounts
Post by InterlagosMC » Thu Jan 26, 2023 12:43 pm
Are you guys in the uk, can’t find anywhere that sells the 034ms mounts
2007 Z4M Coupe
maupineda
Z4m engine mounts
Post by maupineda » Thu Jan 26, 2023 1:22 pm
I am in Mexico, but bought them in FCPEuro during a trip to the US
Beedub
Z4m engine mounts
Post by Beedub » Fri Jan 27, 2023 7:25 pm
Wassup wrote: Thu Jan 19, 2023 2:33 am These came fitted to my Z4MC and were causing major vibrations at idle, the whole interior was shaking as if at 6 on the Richter scale. Once on the move, no vibrations at all and needless to say I changed them for OEM mounts and all is well once more :D
i think i was one of the first that had these mounts and i actually tested the road and race versions for VT... i kept the race ones and sold the road versions. ive found these mounts to be absolutely excellent and in my application they've been put through ALOT of stress , not loads of miles but a whole heap of heat and twisting with a sprint track mostly use. I'm going to have a detailed look at mine this weekend and see how they look and report back.
maupineda
Z4m engine mounts
Post by maupineda » Sat Jan 28, 2023 3:04 am
I am loving the 034MS ones, before, I would not drive the car below 2k, it was too rough and grumpy, at 5-10km/h traffic when you let the car roll, if revs dipped below 1k, I would hear rattles, made me feel the car was falling apart. The new mounts allow me to drive from 900rpms to redline.
Now, I do live in a big city, so in stop-and-go traffic the VT mounts were awful. For those of you in the UK, think of driving though Downtown London in rush hour to get an idea.
