Full Halo/Angel Eyes without cutting the headlight
Submit How-To's here and the moderators will allocate them to the appropriate section
DFR
Post by DFR » Sun Oct 30, 2022 8:40 pm
I was inspired to try this double halo conversion by another "how to" post. I will refer to it during this article as it contains important information on how to access the insides of the headlights.
My headlights are halogen. A little preview o how this will look when done:
Let's get started.
1. Remove the front bumper
viewtopic.php?t=1071&hilit=remove+front+bumper
2. Remove the headlights
Access the headlight hatch from the wheel arch, disconnect the two cables connected to the headlight (forgot to take pictures).
Remove the 4 screws that hold the headlight in place.
3. Clear the outside plastic lens (optional)
I decided to freshen up my headlights following this guide:
https://youtu.be/Xubwpeuqm-E
4. Remove the inside of the headlight
viewtopic.php?t=82010
Cleaning the projector is a must.
5. Fitting the halos
This is where the fun starts.
The hole for the parking and full beam, inside the headlight is about 81mm. I bought some generic 80mm halo LED, but the total diameter of the halo is actually 83mm and the thickness is about 7.3mm.
For the dipped beam halo
I've trimmed the halo right next to the cables and then at the opposite end until I could slide it through the 81mm hole so I could glue it on the chrome ring on the that sits before the projector.
A quick test fit and I realised that the halo will rub against the headlight housing at the bottom and with the plastic cover at the side. I trimmed the plastic halo cover in those places until it fitted.
With hindsight, I should have filed down the whole plastic halo, like I did with the one for the full beam.
For the full beam halo
The halo will sit between the headlight housing and the main beam carrier.
I was concerned that due to the thickness of the halo, the main beam carrier won't have enough space to move around, if adjustment is needed once the headlights are installed on the Z.
I've pulled the LED out and filled the plastic housing down to 6.1mm. You can file it down more if you wish, but at this time my palm muscles were aching like they were on fire and I had enough of it.
Quick test fit and all good.
Final fitment of the halos
At this point, I've touched the inside of the headlight plastic cover to make it smudgy so I gave it a good clean.
The dipped beam halo goes in first and I used the double sided tape that came with the halo to stick it to the chrome ring. The halo cables are on the top side, barely visible. If you ever want to remove the halo, you can pull it out with the chrome ring and then remove the halo, the double sided table is not very strong.
I've routed the cables tight over the chrome ring and once passed it, I used strong tape to glue them to the inside of the headlight (sorry, forgot to take pictures).
The full beam halo goes in next. I used medium strength glue like in the picture below, just in case I ever want to remove them, and glued it to the headlight inside housing.
After half letting the glue cure for half an hour, I reassembled the headlight and spliced into the side lights to connect the halos.
Black LED cable goes to Brown side light cable and Red LED goes to White side light cable. I've linked the two LED back cables together and the two white cables together to save space with the connectors.
My halos are just white but if you were to get the white/amber ones, you would have an extra yellow cable coming from the LED. This would go into the indicator connection.
Once this is done, close the headlight and reconnected to the car plugs for a test fit. Give yourself a pat on the back for the done job!
I've ran out of picture upload allowance. Will post the final result in the comments.
Z4 e85 3.0si
DFR
Post by DFR » Sun Oct 30, 2022 8:44 pm
Z4 e85 3.0si
smorris_12
Post by smorris_12 » Sun Oct 30, 2022 8:59 pm
Excellent write up, I'm putting this on the project list. I must be going daft tho as, having the same age car with halogens, I was convinced I had double projectors!
Scott
Where are we going and why am I in this handbasket?
2006 Z4 2.5si Silbergrau und rot
DFR
Post by DFR » Sun Oct 30, 2022 10:00 pm
smorris_12 wrote: Sun Oct 30, 2022 8:59 pm Excellent write up, I'm putting this on the project list. I must be going daft tho as, having the same age car with halogens, I was convinced I had double projectors!
Thank you and I hope it helps.
Well you do. You have one projector in each headlight which makes it double. :P
Z4 e85 3.0si
DMike
Post by DMike » Mon Oct 31, 2022 4:52 am
Great write up, thanks for sharing. It’s a modern version of building a ship in a bottle! :D
2005 Z4 3.0i Sterling grey
Griffo46
Post by Griffo46 » Mon Oct 31, 2022 9:29 am
Great write up, thanks for taking the time to do it!
2007 3.0si Roadster Stratus Grey/ Red Leather
2016 520d F10 M Sport Space Grey
Zulu4
Post by Zulu4 » Mon Oct 31, 2022 12:22 pm
Really nice job.
Well done. :thumbsup:
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
DFR
Post by DFR » Mon Oct 31, 2022 9:35 pm
DMike wrote: Mon Oct 31, 2022 4:52 am It’s a modern version of building a ship in a bottle! :D
That pretty much sums it up! :D
Z4 e85 3.0si
DFR
Post by DFR » Mon Oct 31, 2022 9:36 pm
Griffo46 wrote: Mon Oct 31, 2022 9:29 am Great write up, thanks for taking the time to do it!
My pleasure dude and have fun doing this!
Z4 e85 3.0si
DFR
Zulu4 wrote: Mon Oct 31, 2022 12:22 pm Really nice job.
Thank you.
Z4 e85 3.0si
dhobbs
Post by dhobbs » Tue Nov 01, 2022 1:40 pm
Great write up :thumbsup:
Do you have a link to the led halos?
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive :driving:
Motor in boot. Bilstein B8 dampers. New radio, much better sounds :thumbsup:
DFR
Post by DFR » Tue Nov 01, 2022 3:02 pm
I've bought these ones but, I've noticed they are all pretty much the same.
Qasim 2 Pcs White 80MM Car Angel... https://www.amazon.co.uk/dp/B078Y6MFNB? ... b_ap_share
Z4 e85 3.0si
Cannon1891
Post by Cannon1891 » Tue Aug 01, 2023 4:51 pm
Great write up - I've recently got a 2004 3.0L, left headlight was letting in water so needs a refurb, After reading above I have ordered the Qasim 80mm rings and will look to do it when I get chance.
My lights have the orange indicators, which I'd consider changing if I could source the clear indicator. The switchback 80mm rings has given me something to think about though as they can act as the indicator, could I just ditch the orange indicator bit and fit something else?? This might just be a bit too much hassle at the moment.
Cheers :thumbsup:
Cannon1891
Post by Cannon1891 » Sun Aug 06, 2023 1:39 pm
HI DFR,
I'm hoping someone can help om here as I have my lights ready to be reassembled, but have hit a minor sticking point.
I've followed the steps above but have a slight flicker/pulse about once every second. I've used the Qasim lights mentioned above from Amazon,
I had swapped the sidelight bulb to LED, but whether LED or the original, I still get this really faint flicker.
Any ideas?
Phil
paddy wright
Post by paddy wright » Sun Aug 06, 2023 3:08 pm
Great job!
