GPS Signal Lost
- dr_john
GPS Signal Lost
My 3 year old G29 has recently started giving the verbal warning message 'GPS Signal Lost' on about 50% of the times that I start the car up.
I understand what this means but my sat nav still functions OK. I'm a bit concerned that it's an indication of something wrong which may turn out to need attention.
Anybody experienced this?
Sapphire Black G29 2.0 MSport with Technology pack
- Scubaregs
GPS Signal Lost
Are you out of warranty?
Quick call to the local dealer might give a solution.
- dr_john
GPS Signal Lost
Yep, I'm out of warranty. That's part of my concern. What could possibly go wrong I asked myself!
I'll check with dealers.
- Scubaregs
GPS Signal Lost
Could try the connected reset, I posted it up in another thread a few days ago.
GPS Signal Lost
Do you have your phone connected via Android Auto (or possibly CarPlay), by any chance? I started hearing the same thing after I enabled Google Maps - I think it's the phone playing the announcement through the car connection. The other clue for me was that the voice is a lot harsher than the BMW voice; ended up disconnecting Android Auto entirely as I don't really use it and I certainly don't need to yelled at every time a GPS satellite disappears behind a cloud!
GPS Signal Lost
I’ve had it twice where the sat nav completely lost it’s location. Hasn’t happened since though.
From my understanding, Apple CarPlay uses car gps anyway?
- dr_john
GPS Signal Lost
I think we have a solution - yes I recently paired a new Google Pixel phone with the car.baljemmett wrote: ↑Mon Aug 29, 2022 1:24 am Do you have your phone connected via Android Auto (or possibly CarPlay), by any chance? I started hearing the same thing after I enabled Google Maps - I think it's the phone playing the announcement through the car connection. The other clue for me was that the voice is a lot harsher than the BMW voice; ended up disconnecting Android Auto entirely as I don't really use it and I certainly don't need to yelled at every time a GPS satellite disappears behind a cloud!
It was a tricky procedure, nothing like the last time I paired a phone. I had to enlist the BMW dealer to help - he had a lot of difficulty getting it to work but eventually did it using Android Auto. Yes, the voice is different from the usual BMW messages.
Thanks!
- pvr
GPS Signal Lost
No, your phone is used for that
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
GPS Signal Lost
Are you sure about this?
I'd assume CarPlay would use the car gps chip to obtain the position, as the phone wouldn't have a reliable signal in the center cubby. Just keeping the phone in your pocket obstructs the gps signal enough to make it useless so I really hope that's not the case.
To my knowledge, OEM CarPlay installations usually use the car onboard GPS, while the third-party aftermarket ones (usually made for older cars), use the phone gps.
GPS Signal Lost
The same started to happen to me after the car had passed the 3 year mark. I hadn't renewed the Connected package and was using Android Auto as I'd lost the RTTI feature.
I disabled Android Auto and purchased the Connected package and the warning seems to have disappeared, but I believe it's the former that was the source of the warning.
- dr_john
GPS Signal Lost
I haven’t renewed my Connected package, I rarely used it.
GPS Signal Lost
Nope, when using wireless CarPlay, it uses car gps.
- pvr
GPS Signal Lost
It uses the data connection from the phone to get accuracy. It needs both
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
