Fuel smell
- bigwinn
Fuel smell
Righto
Suggestions please
54 3.0 manual
Smell of fuel in the cabin on startup
Changed/checked
Fuel line between metal line and fuel rail
Injectors (but still not convinced that Cyl 1/2 o rings looked a bit iffy
Fuel cap seal in good order
Where else would you guys recommend looking?
Anywhere around the DISA/intake?
Intake control
Stuart
Suggestions please
54 3.0 manual
Changed/checked
Intake control
Stuart
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- colb
Fuel smell
You seem to have checked the obvious points, if you have any doubts about any of the injector O rings then renew them all, if one is failing the others won't be far behind. Shouldn't think the Disa or inlet would be the source but do check their joints for any signs of leaks. A smoke test may well be worth doing as this will almost certainly find any air leaks you cannot find visually.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- bigwinn
Fuel smell
Thanks Colb
Process of elimination eh
EWS Delete PM me
EWS Delete PM me
- grannyknot
- bigwinn
Fuel smell
What’s that!?
EWS Delete PM me
EWS Delete PM me
- Mr Tidy
Fuel smell
I think only Ms and Alpinas have one. IIRC it's an extra bit of emissions equipment.
Just found a thread about it here:- viewtopic.php?p=1869261&hilit=bracket#p1869261
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- bigwinn
Fuel smell
Ah gotchaMr Tidy wrote: ↑Sun Jul 24, 2022 6:55 pmI think only Ms and Alpinas have one. IIRC it's an extra bit of emissions equipment.
Yeap I can discount that
Cheers Iain
EWS Delete PM me
EWS Delete PM me
Fuel smell
Is the smell only on start up?
- bigwinn
Fuel smell
EWS Delete PM me
EWS Delete PM me
Fuel smell
Is it possible then it could be something to do with the engine turning over and starter motor or ignition system or spark plugs? It's just weird that it happens on start up only; a leak you would expect to happen all the time. I think you will have trouble finding it if it's just on start up as it's not a consistent issue if you know what I mean. Is it possible not all the fuel is being burnt off on startup and leaking somehow? But once the engine is running it's fine? It could be a heat issue (cold engine or more likely a cold pipe) that once warm expands and seals the leak.
Injectors - you have checked but if you think they could do with a refresh then probably worth doing for peace of mind.
- bigwinn
Fuel smell
Can’t see starter being an issue
I can see leakage if the o rings are waning which may burn off/dissipate quicker when the engine is hot
EWS Delete PM me
EWS Delete PM me
Online
Fuel smell
Hi, bigwinn,
Did you ever solve this issue?
I have a strong fuel smell on startup and since having the car it always revs high on initial cold start but settles to a nice idle, have changed and or checked most things on the car except the fuel injectors, just bought an injector kit and hoping that might solve my issue, anybody done the injectors on an m54?
04 2.2i Sapphire Black Roadster
