Yet another 'Grand Tour' of Scotland
OnlineB21
So getting the last and only of my Yellow Perilsset up for a nice road trip over the next 7 days..technically this will be the longest (in terms of miles) single road trip of Scotland I've ever done.
Just got my baby washed and fettled..for the technical among you I've adjusted my tire pressures to 2.48211 front and 2.7579 rears..I've set boost to a peak of 16 to 18 PSI tapering to 12-14 PSI at redline. Oil and coolant checked..
What could possibly go wrong?
- 2022-05-06 17.14.06.jpg (182.55 KiB) Viewed 641 times
- 2022-05-06 17.14.25.jpg (227.21 KiB) Viewed 641 times
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
Onlinebuzyg
- Argyll Andy
Enjoy, say hello to everyone from us
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- Ole gits rule
Get those pics up as you go
M4 Vert in Yas Marina Blue
OnlineZed Baron
OnlineB21
Day 1 was Jedburgh through Newcastleton onto Gretna, Dumfries and Ospreys at Loch Doon then onto Troon..
- 6CCD3C81-457D-46A0-AA57-4B3BB83FDA7E.jpeg (229.29 KiB) Viewed 523 times
- D369B256-A27E-4402-B086-5B7193EDB762.png (622.93 KiB) Viewed 525 times
- 93866E16-101A-4DFE-9C62-60DAEE468923.jpeg (293.24 KiB) Viewed 525 times
- 7AF4FB39-BEA7-49A9-BDA2-AD422B8A85F4.jpeg (147.63 KiB) Viewed 525 times
- F57A8B00-308C-4165-9347-81D42DA89509.jpeg (197.14 KiB) Viewed 525 times
- 08685554-773D-47BB-9803-B2D8743DC5C5.jpeg (268.2 KiB) Viewed 525 times
- DE4B4E9E-04D1-45C5-AC28-71FB38659F72.jpeg (224.96 KiB) Viewed 525 times
- E22AC722-98CF-4717-AF94-8E8738620532.jpeg (261.94 KiB) Viewed 525 times
- 5DBDE9AF-1762-40C6-9521-F4321DF7FED4.jpeg (223.58 KiB) Viewed 525 times
OnlineB21
Day 2 of the Grand Tour…from Troon over the top to Greenock, around Glasgow, up past Loch Lomond and then onto Loch Fyne then through to Glen Coe and finally Fort William…
- 5240C569-0554-4FBD-A524-495A331C1C71.jpeg (134.95 KiB) Viewed 519 times
- B6891FB2-F1CA-4E62-A974-8851A0FA98DA.jpeg (117.41 KiB) Viewed 519 times
- 31ED5896-2594-4F81-B832-8F54CB24A057.jpeg (105.21 KiB) Viewed 519 times
- 64DA7661-4CF3-4A20-B779-76E815C46B63.jpeg (244.31 KiB) Viewed 519 times
- F0311207-5261-4E8D-A303-04E706C3B3E1.jpeg (238.45 KiB) Viewed 519 times
- enuff_zed
Well done on getting both tyres on each axle to exactly that accuracy whilst still keeping your tongue wedged firmly in your cheek.
OnlineB21
Very good Holmes…I must confess I set up then using PSI but someone demanded the readings in Bar…
OnlineB21
Going solo so was able to get my ballgowns in the boot..just
- enuff_zed
Oh dear!
Everyone hates a bar bore. I always think if you're measuring your distance imperially then you should defer to good old imperial for everything else.
Surprised you didn't reply in KPa and hope they knew how to move a decimal point.
- enuff_zed
Ball gown? Is that like a fancy thong?
OnlineB21
Just didn’t want to embarrass my colleagues…as you know in aviation if you pick the wrong aircraft you have to do knots, statute miles, litres, PSI, hecto pascals, feet, US gallons, metres, flight levels and that’s before you started the engines..enuff_zed wrote: ↑Sun May 08, 2022 9:28 pmOh dear!
- enuff_zed
Do you mean the ECUs??
OnlineB21
ECUs are powered up….it’s gauche to switch one on
