Fitting M3 Control Arms
Whether it's exceptional service or a bad experience, post them here. (Disclaimer: posters views are their own and not that of z4-forum.com)
tiglon
Post by tiglon » Mon Sep 13, 2021 4:36 pm
I bought some E90 M3 control arms to fit to my Z4, thinking I'd just call up my local BMW indy and get them to install them. I've tried 3 local BMW specialists and none seem keen. Two offered to have a look but weren't confident on the headlight levelling sensor issue. The third refused to fit supplied parts due to insurance, but quoted for supplying themselves and fitting - more expensive and I'd need to sell or return the parts I already have. He did seem very relaxed about the sensor issue, but I think that might have been because he stopped listening when I said I'd already got the parts.
Has anyone had this done previously and can recommend somewhere? Happy to travel a bit.
2014 E89 35is Valencia Orange 788M wheels (M2 Competition), E90 M3 control arms, Eibach Pro Kit Springs, MHD Stage 1
Online
Argyll Andy
Post by Argyll Andy » Mon Sep 13, 2021 4:42 pm
I’m sure John-E89 has them on his 35i. Don’t know if there’s differences between that an the iS.
    E89 23i sDrive, Silver (Gone)
    tiglon
    Post by tiglon » Mon Sep 13, 2021 5:35 pm
    Thanks Andy, as far as I'm aware the 35i and 35is are exactly the same in this respect.
    Ed.Straker
    Post by Ed.Straker » Mon Sep 13, 2021 7:41 pm
    I'm looking at this too.
    The eponymous pbondar on this forum did this himself..if you search you should find a write up.
    The issues are that the headlamp leveling is on the opposite side to that on the M3..so the bobble that the self leveling arm connects to has to be cut off from its location on the old arm and fixed somehow to the new arm.
    A chap in the States did it with tie wraps and looked pretty horrible.
    I believe pbondar used aerospace glue to fix his.
    Because the linkages are not identical a full 4 wheel alignment will be required post fitment.
    That is if you do the rear bearing mods too.
    I would imagine that any cutting and shutting will have the average dealer running for the hills.
    White 35i MSport MHD re-map…still in one piece
    Atacama Yellow 20i MSport Auto. Remapped, more to be done…written off
    tiglon
    Post by tiglon » Mon Sep 13, 2021 9:55 pm
    Thanks, I've read a couple of write ups but I just don't have the space/tools to do it myself. One indy suggested they might drill a new hole in the other control arm, but it really doesn't sound as complicated as that. I'll keep searching for somewhere that seems a bit more confident, otherwise get one of the local guys to have a look.
    Ed.Straker
    Post by Ed.Straker » Tue Sep 14, 2021 11:15 am
    Drilling a hole in a steering linkage I think is an exceptionally bad idea..if it was OK why didn't BMW do it?
    tiglon
    Post by tiglon » Tue Sep 14, 2021 2:18 pm
    Ed.Straker wrote: Tue Sep 14, 2021 11:15 am Drilling a hole in a steering linkage I think is an exceptionally bad idea..if it was OK why didn't BMW do it?
    That was my thought, hence definitely not using that particular garage.
    tiglon
    Post by tiglon » Fri Oct 22, 2021 5:37 pm
    Finally got these fitted - by MStyle in Romford, for reference if anyone else is looking to do the same.
    B21
    Post by B21 » Fri Oct 22, 2021 8:46 pm
    tiglon wrote: Fri Oct 22, 2021 5:37 pm Finally got these fitted - by MStyle in Romford, for reference if anyone else is looking to do the same.
    How much did they charge?
    Did you see how they did the level sensor adjustment?
    A very modified Atacama Yellow 35is :thumbsup:
    tiglon
    Post by tiglon » Fri Oct 22, 2021 9:59 pm
    B21 wrote: Fri Oct 22, 2021 8:46 pm
    Total was around £280 including alignment. They got a new sensor (I think, need to double check that) and cable tied it to the arm. Maybe not a long-long-term solution but it will do for now and I can visually check it every month or so, perhaps glue it or make a bracket at some point.
    B21
    Post by B21 » Fri Oct 22, 2021 10:34 pm
    tiglon wrote: Fri Oct 22, 2021 9:59 pm
    Noted thnx..not impressed with their sensor attachment solution but I guess it works..
    tiglon
    Post by tiglon » Sat Oct 23, 2021 2:01 am
    To be fair to them, "It works" was really all I asked for. :thumbsup:
    B21
    Post by B21 » Sat Oct 23, 2021 9:31 am
    tiglon wrote: Sat Oct 23, 2021 2:01 am To be fair to them, "It works" was really all I asked for. :thumbsup:
    Quite so..I’d picked up elsewhere that MStyle weren’t big on engineering….
