How-To: E86 CD changer cables for BlueMusic Bluetooth
- chanlon1
Had bought a bluemusic device off another forum member and installed it in my coupe today.
I tried to lift just the panels in the boot and wedge them with blocks, but just couldn’t get the space I needed. Ended up stripping all the panels and carpets in the boot. Having done it now, I’d imagine it would only take minutes to do it again, but was very straightforward.
E86 Z4 Coupe 2006 Silver
- inkey$
it gets pretty tight back there, but glad you managed to sort it even if that meant stripping it all out.chanlon1 wrote: ↑Thu Mar 16, 2023 5:50 pm Had bought a bluemusic device off another forum member and installed it in my coupe today.
Previously: Z3R 2.8 • E46 330i • Z4R 3.0 • Z4///MC • E90 335i • Z4///MR • Z3///MC 'Breadvan' • Z3R 2.8 • E30 325i R • Z4C • Z4R 3.0
- chanlon1
Once you know how it’s attached, it’s simples taking it apart again.
I did find a torx screw, a pencil and some unused cable ties all under the carpets. Makes me wonder what was going on when the iPod kit was installed!!
- inkey$
Started the job of finding the cd changer connectors in my E86 today… instructions of how to get to into the hole in the bulkhead were spot on… but for the life of me I can not find the cables!
There are cables in there but even with decent tugs they’re not coming free and they’re not the same colours as those shown on this thread.
Has anybody found that these cables just aren’t there in their E86? Any other tips or advice?
Cheers, Matt
Cheers, Matt
- chanlon1
I’ll ask the obvious. Does your car definitively have the CD prep option when you check the VIN details?mattimus wrote: ↑Sat Apr 08, 2023 6:04 pm Started the job of finding the cd changer connectors in my E86 today… instructions of how to get to into the hole in the bulkhead were spot on… but for the life of me I can not find the cables!
Cheers, Matt
Sensible question - yes I think so… mdecoder.com gave me this -
- 30A74616-9F87-4E6B-9062-A0294F630699.jpeg (37.32 KiB) Viewed 633 times
- chanlon1
Looks like you have it okay. Did you remove the boot linings and carpets to access the little compartment where the cables should be, or did you cheat and just lift the vertical piece of carpet a couple of inches?
I’d suggest removing all as it will allow a better view. Doesn’t take too long and is a pretty simple job.
I cheated and propped up the linings a few inches… high enough to have a fairly decent rummage around… nervous that I won’t be able to reach much further even with the lining right out of the way.
Also nervous about removing trim, breaking clips etc!
- inkey$
If you have the changer prep then they should be in there somewhere. Try seeing if they are flat or taped against the metal of the bulkhead. Or if you can, get a phone camera up in there so you can see whats going on. Otherwise you might need the trim removing fully.
- chanlon1
It’s not as bad as you think.
There are a few clips involved, but nothing great.
When you start to remove them you can only do it in a certain order. One piece of plastic I removed had a clip missing and it wasn’t obvious.
However, once it’s all removed it gives great access.
As above, shove your camera in there and take some photos or video to see what you have.
- inkey$
….and post the photos on here if you can, in case it helps others
Yep not that bad… I didn’t bother completely removing the side and back panels as I had acres of space and the connectors practically jumped out and smacked me in the face - no idea how I didn’t find these before, they were right there!
Took a few images including just poking the camera around inside the hole in the bulkhead just in case it’s useful for anyone - they appear in reverse order.
- D5029ADC-FE12-46EA-B898-23CA14CDC950.jpeg (128.03 KiB) Viewed 613 times
- 483A46E1-5061-484F-B401-EBA216992407.jpeg (109.42 KiB) Viewed 613 times
- C73E6A7D-2E43-4AC9-83C9-C84B2299DE14.jpeg (134.79 KiB) Viewed 613 times
- 6E5C7819-D60A-4243-80A2-8048C790A72B.jpeg (119.72 KiB) Viewed 613 times
- 17B92236-EBE0-4EA9-8B5B-91EB6E3E2149.jpeg (126.01 KiB) Viewed 613 times
- E535EE89-5A28-41B9-9F99-104806EEDE6B.jpeg (75.72 KiB) Viewed 613 times
- B71FB33B-D44B-4E48-B421-464F71A9C1DE.jpeg (143.97 KiB) Viewed 613 times
- 46A1BA87-0C41-40FA-9A78-B88B6F09BD37.jpeg (138.75 KiB) Viewed 613 times
Just bought the 3,000th one of these!
- 6683F0F4-5E81-4484-89ED-3B2772651336.png (179.77 KiB) Viewed 613 times
- chanlon1
Great that you found it.....however your boot looks an absolute site with the carpets/trims half pulled out!
I bought one of those BlueMusic toys off a forum member bout a month ago....excellent piece of kit.
