Seems to be at low speeds. Doesn't make a noise, at least that I can hear, at motorway speeds and going in a straight line.
It sounds like crunching plastic inside the dash. (Possibly the centre top part). I've tried moving the steering wheel to see if that affects it and I don't think it is linked as there is no consistency with the noise it makes.
I've heard it do they odd pop/crunch when I'm sat idle. This was when it was a hot day and I'd been out in the car for a bit.
Any ideas what it could be as I'm dreading taking it to a garage as I'm guessing it will cost a lot to investigate.
Noise has never been about until about a month ago. Now it is making it all the time.
Dash making crunching noise [solved]
- Z4C_er
The 'noise in the dash' problem often gets raised here and it seems that looking under the bonnet may be a possible first step. Check and tighten the brace mounts to the firewall.Skella wrote: ↑Mon Sep 21, 2020 8:03 pm Seems to be at low speeds. Doesn't make a noise, at least that I can hear, at motorway speeds and going in a straight line.
See how that goes.
2006.5 E86 Z4C si SE Phoenix Yellow
Get some silicone bumper spray and apply to all joints. When i first had my car i would get a noise like stones hitting windshield. It was the plastic creaking. Also stick some rubber pads between visors and the plastic they sit against, they creek.
- mr.tourette
Is there a solution to the creaking armrest on the door panel, pretty much the only one on my car but can't really see a solution, there is leather and alcantara on the door so spraying silicone there is not really viable
Thanks for the advice. They were super tight. Loosening them up has now stopped the noise. I'm over the moon as I've not had to take it the dealerZ4C_er wrote: ↑Mon Sep 21, 2020 8:15 pmThe 'noise in the dash' problem often gets raised here and it seems that looking under the bonnet may be a possible first step. Check and tighten the brace mounts to the firewall.Skella wrote: ↑Mon Sep 21, 2020 8:03 pm Seems to be at low speeds. Doesn't make a noise, at least that I can hear, at motorway speeds and going in a straight line.
See how that goes.
