Style 32 weights
- Warming
Style 32 weights
Hi I'm trying to find out the wheel weights of 17" and 18" style 32 wheels. If I find a set locally I will try to weigh them and let you know.
I've seen posts on forums suggesting they are less than 10kg, but others saying they are over 11kg.
Some posts that I've read seem to suggest the 18" versions are lighter than 17" - there are a few sources of wheel information out there but wondered if anyone had actually weighed the wheels by themselves on the scales.
Threads for ref:
viewtopic.php?t=80830
Source of info:
http://www.bmwstylewheels.com/bmw/32
Many thanks
Threads for ref:
Source of info:
Many thanks
Style 32 weights
Which specific wheel (diameter & width) are you looking at, as there isn't a single weight for any size.
The smallest, least sturdy one for an old e36 compact might only be 8kg, and the largest, sturdiest one for a newer, heavier 7-series might be 15kg.
For example, the BMW parts catalogue (bmwfans.info) says::
- 7Jx15et47 (85329409883) for an e36 is 17.8lb/8.1kg
- 8Jx17et7 (85329408696) for an e36 is 19.6lb/8.9kg
- 8Jx17et7 (36111095337) for an e36 is 22.9lb/10.4kg
- 8Jx18et20 (85329409952) for an e39 is 24.8lb/11.3kg
- etc.
- Warming
Style 32 weights
Yes that's why I'm looking to see if anyone has weighed their own, with part numbers would be great
Looking for E46 or Z3 17" & 18" 8-8.5J Style 32 wheels.
Style 32 weights
According the BMWFans.info the wheels for the e46 are:
- JamieZ4C
Style 32 weights
I have genuine E46 wheels on mine. Part numbers are 36111095340 (fronts) and 36111095341 (rears).
According to realoem (I know, I know) the weight of my 32s are 9.100/kg front/9.500kg rear.
And according to realoem (yes, I know) the weight of 108s is 11.226kg front/13.000kg rear.
So, while I'm not going to take my wheels off the car, remove the tyres and weigh them for you, I hope that is of some help
- JamieZ4C
Style 32 weights
Some pics just taken in work car park...
- Warming
Style 32 weights
Thanks chaps, that's very helpful, gives me something to go on.
If I can get simply a wheel & tyre weight,
it should give a rough indication of the weight,
and I can always estimate the wheel weight by subtracting the quoted 'brand new' tyre's weight.
Will update with numbers if I can get a set to weigh.
Style 32 weights
Won't the online tyre weights also be subject to as much variance as the online wheel weights?
Style 32 weights
A tyres weight is arguably more important than the wheel as it’s furthest from the point of rotation. One of the tyre reviews videos listed some weights of several major brands and I seem to remember the vredestein, whilst a decent performing tyre, weighed almost 2kg more per tyre than the Goodyear equivalent. That’s enough to offset the savings a pretty expensive set of wheels might give you.
RUBYIMOLACARBON
- kis
Style 32 weights
I’ve got some 18” stashed away. Will dig them out and get some weights for you.
Not sure how correct sites may be, but they feel quite light, even with tyres they seem light. Without and it’s quite strange how little they weigh.
Won’t be till the weekend mind you!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
Style 32 weights
Forgot to update!
Front alloy is 9.1kg which is reflected in Real OEM
36111095340
Light alloy rim
8JX18 ET:47
Part 36111095340 was found on the following vehicles:
3' E46 (04/1997 — 08/2006)
Rear alloy is 9.2kg which is almost the same as Real OEM
36111095341
Light alloy rim
81/2JX18 ET:50
Part 36111095341 was found on the following vehicles:
Hope this helps
36111095340
Light alloy rim
8JX18 ET:47
36111095341
Light alloy rim
81/2JX18 ET:50
Hope this helps
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- JamieZ4C
Style 32 weights
Brilliant, well done for remembering to update, Kis. Some very interesting numbers there - especially the weight of the rears. Heck of a saving over the standard 108 or MV2s for example.kis wrote: ↑Sun Oct 04, 2020 11:20 am Forgot to update!
36111095340
Light alloy rim
8JX18 ET:47
36111095341
Light alloy rim
81/2JX18 ET:50
Hope this helps
Roughly 2kg saving on the fronts and 4kg saving on rears. 12kg overall. Nice
- kis
Style 32 weights
Welcome bud
Not sure why my rears are lighter than normal (i.e. Real OEM)
I did double check and I used a 5kg free-weight as control for the weighing scales. So I know my weighing scales are accurate.
Defo a good OEM option for wheels... not cheap tho!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Warming
Style 32 weights
Many thanks kis & JamieZ4C!
