Wiring in door speakers on a 6 speaker system?
aqua0
Post by aqua0 » Tue Jul 07, 2020 3:56 pm
Hi All,
Just wondering if I change the door harnesses that are currently installed, and switched them for the harnesses that are used in the 10 speaker system, would that enable the door speakers to work, or would I need to add something else - amp etc?
Asking as I managed to get a set of 10 speaker door harnesses as the guy didn't want them and just figured it would be a neater fix than wiring the door speakers to the tweeters.
Thanks in advance.
Never go deeper than the bottom :P
Facelift 3.0Si Roadster :thumbsup:
Previous was a 2.0i Sport
Z4C_er
Post by Z4C_er » Thu Jul 09, 2020 12:23 pm
Well, I guess that would give you an extra cable to the mids, but apart from that, what else would you gain? You currently have no speakers in the door (just a blanking plate) so if the aim is to be adding speakers, then that just involves fitting the items and running a cable through the existing door interconnecting rubber tube. I don't know if the current loom has the speaker cable for the mids on the car body side, so it could all be a waste of energy. I'd just run a new cable through the door. I bought an underfloor oxygen free hifi cable which seems to be of very good quality and has the advantage of being slim enough to fit in the available space in the door connection:
2006.5 E86 Z4C si SE Phoenix Yellow
aqua0
Post by aqua0 » Thu Jul 09, 2020 2:54 pm
I was more thinking that it would hopefully be a plug n play but I’m not sure if it would be that simple on the basic 6 speaker system head unit?
Z4C_er
Post by Z4C_er » Thu Jul 09, 2020 6:57 pm
aqua0 wrote: Thu Jul 09, 2020 2:54 pm I was more thinking that it would hopefully be a plug n play but I’m not sure if it would be that simple on the basic 6 speaker system head unit?
Yes, not sure. I don't think I saw extra wires on the car body interior side.
George7
Post by George7 » Tue Oct 20, 2020 1:23 pm
Hi
Please tell where you connected on the rear of the radio. Did you break into the mid range units in the rear cabin wires? I've fitted two mid range speakers in the door and at the next stage of wiring and am interested in your solution. Also where did you get the wire you describe from?
George
X5 30i
530 GT
420 M Sport Plus Grand Coupe-hardon karmon,19" alloys, pro nav, sun roof
Z4 2.5 Roadster, cruise, xenons, sports suspension, red leather, heated seats, heated folding mirrors, aux fitted, 107s, roof motor in boot.
aqua0
Post by aqua0 » Tue Oct 20, 2020 2:12 pm
George7 wrote: Tue Oct 20, 2020 1:23 pm Hi
George
Hi matey. I just spliced the new door speakers into the wiring to the door tweeters matey.
aqua0
Post by aqua0 » Tue Oct 20, 2020 2:13 pm
George
Hi matey. I just spliced the new door speakers into the wiring to the door tweeters.
George7
Post by George7 » Wed Oct 21, 2020 9:08 am
When you say 'spliced' did you use scotchlocks, solder or other connectors please. What was the resulting sound like?
George
X5 30i
530 GT
aqua0
Post by aqua0 » Wed Oct 21, 2020 10:13 am
Hiya. I just used splice blocks (little blue plastic things with what looks like a metal W piece inside them)
For the cost of a couple of BMW 4” speakers and an hour to fit them, I’m genuinely happy with the improvement.
George7
Post by George7 » Wed Oct 21, 2020 10:20 am
Fab, they're called scotchlocks, I've had the speakers installed for sometime now, I think I'll get on and wire up👍👍👍👍👍
X5 30i
530 GT
Perjorative
Post by Perjorative » Wed Oct 21, 2020 5:42 pm
Look at this thread for detailed instructions
viewtopic.php?f=31&t=53812
George7
Post by George7 » Wed Oct 21, 2020 6:48 pm
Thanks mate, I've decided to give a try tomorrow 😷😷😷👍👍
X5 30i
530 GT
George7
Post by George7 » Fri Oct 23, 2020 12:35 pm
Hi
Just to let you know, I cut the wiring I found to the door mid range speakers, so as to us the connectors. Then used scotchloks to the tweeter wires and it works. Great improvement, but I haven't found the perfect balance and tone yet!!
Thanks for the info.
George
X5 30i
530 GT
aqua0
Post by aqua0 » Fri Oct 23, 2020 12:51 pm
:thumbsup:
