I need all your help with this one. Picked up my Z4 drives great slight problem with steering at high speed gets a bit light and twitchy!
Thought this might be the tyre pressures all out and not to my surprise it was. Not knowing what to put in to them psi wise i put 40psi all round. the ride is alot heavier true to its line. tried reading the tyre recommendations on the sticker but doesnt really understand them as they arent in psi. i have a 3.0l si sport convertible so anyone with this car or similar please post what pressures you put in so i can get my z riding the way she should!
ps i have the 18'' multispoke wheels if that makes a difference as you can see it my lil pic <-----------------
Tyre Pressures
- ell_p
Tyre Pressures
06 Z4 3.0si Sport Roadster, Black Sapphire, Octagon Red Leather, MV2's, Michelin ZP PS2's, Black 2.5si Kidney Grille, Stubby Aerial, Tints all Round, Private Number Plate
- WLH
Re: Tyre Pressures
I believe 40 psi might be a little high. I usually run around 34 to 36 psi and that seems to work well for me with my Goodyear F1 tires.
- sp3ctre
- Site Admin
Re: Tyre Pressures
I agree with WLH, I think 36 would be as high as you'd want to go.
- highstream
Re: Tyre Pressures
got 37 back and 35 front
- Wondermike
- Moderator
Re: Tyre Pressures
33 front and 36 rear for me.
- skelters
Re: Tyre Pressures
If it's Runflats you've got then that's an added feature to the handling of the car.
The solution is to change them to other tyres and the handling instantly improves..
2007 Z4 3.0si Sport. Silver Grey Metallic, Brembo Brakes, HEL Braided Brake Hoses, Machine Monkey Exhaust Tips, Stubby, Piano Black trim, Black Leather, Bilstein B12-Pro-Kit, Michelin Pilot Sport 4 on MV2's. Roof Motor in the Boot!
- BMW^Z4
Re: Tyre Pressures
I use 2.0 front and 2.3 rear on 18", 108, pilot sport 2..
Sterling grey ,108 starspoke, alarm,KW v3 suspension,clear lights,cd/mp3, ipod 20GB, hardtop,manual,wind deflector, aerodynamic package, silver trim,Michelin pilot sport tyres, cruise control etc ...
Re: Tyre Pressures
The tyre pressures on the door sticker are in 'bars' a metric pressure unit where 1 bar is 14.5037 lb/in2. Thus 2 bars is 29 lb/in2 etc, etc.
Easy to work out with a calculator make a note to keep in the car and you'll be fine.
FWIW 40 psi (cold) is way too high for the road. IIRC a 3.0l on 18" wheels is 33F and 36R, a 2.5 on 18's is 30F and 33R both cold pressures. Warmed up they were close to 40. I used to run my 2.5 with M susp on 18's at 33F and 36R as short journeys didn't warm the tyres up much and it gave better ride and handling.
I'm on my second Zed, a cosseted 2007 Interlagos Blue Z4M Roadster owned since new - 343 horses controlled by a donkey...
Daily driver is a 2012 X3 3.0d M Sport (fantastic) Wife has a 2015 325d Luxury
IAM Observer
IAM Observer
