Since I bought my Z4 I always thought that the lighting in the boot is really inadequate, especially if you got some things in the front part of the boot near the opening it blocks the single original light fitted and the rest of the boot is then very dark!
So I decided to add some more light. I had some LED neon strips lying around so fitted one of them. The process is really very simple and easy which anyone can do in about 15 to 30 minutes. I opened the roof so the boot would open upright and that way you have access to the rear bulkhead panel and fitted the led strip to the top of this:
I run the cable from the LED strip down behind the trim panel that usually hides the amp and from there below the trim on the boot floor, you can do this without actually removing any trim, just lift it little and tuck the cable in:
From there I ran the cable alongside the car's original cables and tied it with zip ties. I connected the cable from the LED strip to the cable coming from the existing boot light using a t-splice quick connector. I used expanded fabric sleeving (can't remember the actual name for it) so to keep it looking neat and almost OE!:
And this is the finished results, with the boot partition up and with it down. As you can see regardless of where the boot partition is it illuminates the entire boot area quite well. From normal viewing angle / height you cannot see the LED strip at all. It is only really noticeable if you crouch down on your knees and look up into the boot.
Extended Boot (Trunk) Lighting
- MrPT
Fantastic.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- enzed4
I like that - well done .
Do you have a link to the LED strip you used?
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
I used the ones in the ebay link below. I bought them quite some time ago but didn't do anything with them, as you can see from the link they are actually flexible DRL dual colour led strips. Since I had them lying around I used them I just didn't bother connecting the yellow indicator wire. Maybe I should have done that and make the boot flash yellow with the indicators
https://www.ebay.es/itm/2-X-60CM-FLEXIB ... 4d5b90b363
What a great idea!
E89 Z4 2.3i
E85 Z4 2.0i (Sold)
F10 523i Touring
E82 125i M Sport Edition Plus
E36 Z3 2.8i widebody
R65 ‘Airhead’ (Restored and sold)
E85 Z4 2.0i (Sold)
F10 523i Touring
- Singapore stag
How did you secure the lights onto the back?Silverstar wrote: ↑Sat Feb 01, 2020 9:54 pm I used the ones in the ebay link below. I bought them quite some time ago but didn't do anything with them, as you can see from the link they are actually flexible DRL dual colour led strips. Since I had them lying around I used them I just didn't bother connecting the yellow indicator wire. Maybe I should have done that and make the boot flash yellow with the indicators
- Smartbear
Those light strips are generally self adhesive on one sideSingapore stag wrote: ↑Wed Feb 05, 2020 2:56 amHow did you secure the lights onto the back?Silverstar wrote: ↑Sat Feb 01, 2020 9:54 pm I used the ones in the ebay link below. I bought them quite some time ago but didn't do anything with them, as you can see from the link they are actually flexible DRL dual colour led strips. Since I had them lying around I used them I just didn't bother connecting the yellow indicator wire. Maybe I should have done that and make the boot flash yellow with the indicators
e85 3.0si sold
These strip lights don't have self adhesive on the back but they come with little clips with tiny screws, you can just about see them in the photo I posted. So I just screwed the clips to the felt / fabric panel and then mounted the strip to it. That panel being made of some sort of fabric I am not sure how well self adhesive tape would hold or if for any reason I wanted to remove it, if it would make a mess of the panel. This way I can revert back to original without any visible damage to the panel.
