135i Calipers Fitted to Z4M
I used the genuine 34116786044 pads and had zero fitment issues.
E85 M, Aero Skirts and Hardtop
Schrick 288/280 Cams and Rockers
Karbonius Race Airbox
BMW Motorsport 4.1 FD
Supersprint Full System inc 100 Cell Cats
163M CSL Rims
Bilstein/Eibach B12
Recaro Sportster CS
Diagnostic scanning and coding in Essex
163M CSL Rims
Bilstein/Eibach B12
Recaro Sportster CS
- B21
Textar OE pads and Brembo HP pads work perfectly..
OnlineEd Doe
But you're not using the same (CSL) discs on your E89 though right?
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- B21
Correct I’m using the ‘correct’ discs…but his issue was the pad ‘sticking’ in the caliper ?
OnlineEd Doe
No, OP's issue is the overall pad depth plus disc thickness dimension is greater than the dimension between the opposing pistons in the caliper. Just means you saying you've not had issues with your pads is not strictly relevant and may introduce confusion as your setup isn't quite the same as it's fitted to your e89, that's all! (not meant in a sh***y way, just that at first glance it may genuinely be confusing!)
- B21
Thank you for clarifying..always the danger coming into a conversation mid way..Ed Doe wrote: ↑Wed Jan 10, 2024 1:03 pmNo, OP's issue is the overall pad depth plus disc thickness dimension is greater than the dimension between the opposing pistons in the caliper. Just means you saying you've not had issues with your pads is not strictly relevant and may introduce confusion as your setup isn't quite the same as it's fitted to your e89, that's all! (not meant in a sh***y way, just that at first glance it may genuinely be confusing!)
What’s the CSL disc thickness ?
339 x 26mm I think is the ‘official’ disc?
OnlineEd Doe
No worries, as I say not trying to be an internet arse, just trying to avoid confusion!!
See below quote of an earlier post - seems the CSL disc is 28mm thick
- B21
Well that answers a question I had as to why they had used a relatively thin disc..
You can get brackets that allow the 330i 325x25mm disc.
This would solve my problem, easily.
But, if we're gonna do this, lets dot it! - 345x28mm CSL disc it is!
(but I need to break out the belt sander and shave .5mm of the pads, first.)
E86 3.0si - Koni, Eibach, Eisenmann. viewtopic.php?t=143973
F31 340i MPPSK - Carrying family, bikes, kayaks and everything else.
- 3gGT01
Thinking that questions on Brembo caliper paint matching might be better placed elsewhere on the forum. Oops!
2007 Z4MC Interlagos Blue Metallic w/Light Sepang Bronze Nappa interior. 'Emma'
OnlineEd Doe
Any more updates Meds?
I ordered the brackets yesterday.
I was planning to get them from a guy on M3 Cutters who's been supplying them to the M3 boys for years.
But he was not convinced on the comptibility on the non-M Z4's.
So, I ordered from here:
https://epytec.de/de/bmw-performance-br ... achse-2176
They'll be a few weeks in transit.
I've been meaning to get outside and shave a touch from my 'oversized' Brembo pads. But it's been so cold.
OnlineEd Doe
The E46 M3 adapters wont fit the 3.0si (non-M) hubs, if that helps at all! I bought mine attached to M3 hubs with M3 adapters, so I took those off and sold them on, and then bought the epytec.de ones you've boughtMeds wrote: ↑Tue Jan 16, 2024 3:40 pmI ordered the brackets yesterday.
But you were running these on your M.?
Or non-M. ?
