Vanne's lightweight/ interior modification thread
- Vanne
Removed a few of the legacy gauges i modded in a few years back yesterday and stripped the loom a bit further as the rain module doesn't need to be there. Prepping the dash loom for the Racepak today.
cars absolutely filthy atm.. lol
I also got a new race batt. The braille 11 was on the way out. sad really as they are pretty expensive. I opted for a LiFePO4 battery, due to the safety aspect of not wanting to overheat and catch on fire/punctured. weighs in at 3.2kgs, so lighter than my old Braille.. absolutely amazing battery. The form factor is larger than the Braille, but the weight is much less.. easy 1.5kgs saved. thats a few more big macs i can have
Powered by Severn Tuning
- 1536Z4
Coming together now Vanne but have to ask of all the colours why black it must get very hot ??
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- Vanne
lol, its not actually black..
- 1536Z4
Must be my Mr Magoo eyes Is it Super Hero Dark Blue ??
- Vanne
Hahaha, nah it's metallic dark green.
- Barty
Im feeling a vague sense of deja-vu… like staring at an evil twin
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
- Vanne
Lol, thanks Bart
Okay, just a heads up for those looking at a racedash.. Probably best to stick to the tried and true methods like Aim, as Racepak isn't really compatible with our stock ecu. works great if you have an aftermarket ecu, but not for stock. Probably should have known that as there are zero write ups for BMW with rackpak dash'es. The older ones do work, but your having to buy sensor modules. Its an expensive exercise.
__________________
__________________
- 1536Z4
Are you going to stick with Racepak and find a work around or sell it and move on ?
- Vanne
In cohorts with @martyn here, hopefully make some headway. I gotta say as well, the support from either Holley or Racepak is frikkin non existent.. stay tuned.. failing this I will go the mxl2 route. I do like the Racepak look better, but if I can't get it to work I'll be forced. There are options for obd2, but I'll need canbus.
- Vanne
- 1536Z4
- Vanne
Thanks, with Martyn’s help and his hex locations for the IDs on the can bus, it took a bit of trail and error, but at least I knew in which direction to poke.
- Vanne
- Vanne
Thanks to Martyns help, I’ve got rpm, speed, oil temp, water temp , fuel level and a bunch of others sorted on the canbus for the race dash, which now I’ve got it working I’ve replaced with a logger version of the same dash.
- Vanne
doing a spot of dash coding, Yay, fuel gauge now working too
