YAY!!!!! can’t wait! Look forward to getting them fitted
FOR SALE B-06 hand brake handle and gear knob set!
- IAmOrion
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
- JINGLE
Just sent payment and looking forward to seeing how good these look in the flesh!
Did you manage to get these posted
i sure did. you beat me to it i was just about to message that they have all been posted.
im going to do a step by step fitting guide tomorrow on how to fit them, its not hard getting the old one off can be quite tricky.
i didn't realize you are only a few mins down the road from me, i had to go down to dpd today i could have dropped it off
Just to say many thanks that my set arrived today and they look fantastic. Will wait for the fitting guide before doing something wrong
James
Z4MR
James
Z4MR
Coppins999 wrote: ↑Thu Nov 01, 2018 11:55 pm Just to say many thanks that my set arrived today and they look fantastic. Will wait for the fitting guide before doing something wrong
James
Z4MR
Cheers James,
I will put it up tonight I finish work at 3 today so should have plenty of time to do it.
So here we go.
Hand brake you need to pull and twist the old one until it pops off. It can take some effort!
Then drop the button inside your new handle and slide it over the lever, that should be in the engaged position. Let it sit there on it own weight, DO NOT PULL IT BACK and tighten the grub screws like picture 1. Warm the leather boot up with and hair dryer that should make it more malleable. Slide it over the attached handle. Put the cable tie in and pull it as tight and you can.(pliers help with this). ^^^Pictures 2 and 3^^^
Pull the boot back over clip into place and you have your shiny new handle
- JINGLE
Fitted both, wow what a great look
- LittleZ4
Just installed mine. Cheers Buckley
Might have to find a new boot to do it justice.
On a side note to anyone finding it difficult to remove the old handle, a couple of light taps with a hammer from the base shifted it with ease.
- IMG_20181104_134301.jpg (198.68 KiB) Viewed 5547 times
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
Love it!
I think my handle had been taken off before as I came off really easy.
How did you find fitting the handle?
- LittleZ4
Easy!! Was a tight fit but everything went together without a hitch.
Hmm! Any of these left? My handbrake is looking worse for wear with it being 14 years old, gear knob ain't great either!
I sure do, pm me with what you want.mjennings23 wrote: ↑Tue Nov 06, 2018 1:18 pm Hmm! Any of these left? My handbrake is looking worse for wear with it being 14 years old, gear knob ain't great either!
- Chris_D
Thanks Oliver. Received in good order.
Can't wait to fit at the weekend.
Finish is top notch
Finish is top notch
Mine arrived yesterday, not fitted yet but looks a first class job, many thanks- Keith
