How-To - e89 Cruise Control Retro-fit
How-To articles are in here.
AnubisZed
Post by AnubisZed » Sat Mar 28, 2020 9:50 am
CorZZZZ wrote: Sat Mar 28, 2020 6:20 am The stalk i bought was a 6989557-01, not compatible, info from the buyer it was from an E90.
Yeah unfortunately that part number is only for the slip ring and it is compatible with the e89. I can also assure you, and others, that the e90 stalks ARE compatible with the e89 as well. So this can only be down to a faulty set of stalks and not a compatibility issue here. I've done a lot of cross-referencing and superseded checking on all possible combinations for these so you can get the most economical way to do this mod.
I would put up a list of part numbers, but a lot of sellers just put the slip ring number which doesn't help.
Dave
2011, 23i, Grey with Red leather. 8)
AnubisZed
Post by AnubisZed » Sat Mar 28, 2020 11:52 am
And just to confirm that it is compatible.... (don't forget this is ONLY for the coil spring, not the stalk assembly!)...
Dave
cvhuis
Post by cvhuis » Sat Mar 28, 2020 7:00 pm
Ok, then it must been a faulty stalk, but I brougt it back and get my money.
Ordered another in Ebay and these one is okay as said.
TX again for your support and great How-to!!
vld
Post by vld » Fri May 08, 2020 7:31 am
Can anybody share the "NCExpert Profiles"? The download link in the guide is no longer valid. Thanks!
(Sweden) E89 2012 20i Melbourne Red, Smart-top, Android display, 2.8i mapped, Retrofitted: cup holder and cruise control
AnubisZed
Post by AnubisZed » Fri May 08, 2020 8:36 am
vld wrote: Fri May 08, 2020 7:31 am Can anybody share the "NCExpert Profiles"? The download link in the guide is no longer valid. Thanks!
Have you looked at the latest version of the 'How-To' pdf?
In fact if the are using the Beemergeeks NCSExpert then it comes with profiles already loaded :thumbsup:
Dave
vld
Post by vld » Fri May 08, 2020 8:56 am
I am following the guide. The download link in the guide is broken.
Skipping that results in this:
vld
Post by vld » Fri May 08, 2020 11:39 am
I managed to complete the coding with some profiles I found here: https://www.e90post.com/forums/showpost ... count=4476
vld
Post by vld » Sat May 09, 2020 7:18 am
Well, I thought everything went fine, as everything seems to functions right, but I lost my lights indicators on the instrument cluster. Any ideas?
AnubisZed
Post by AnubisZed » Sat May 09, 2020 9:04 am
vld wrote: Sat May 09, 2020 7:18 am Well, I thought everything went fine, as everything seems to functions right, but I lost my lights indicators on the instrument cluster. Any ideas?
What indication, can you elaborate please
Dave
vld
Post by vld » Sat May 09, 2020 9:21 am
AnubisZed wrote: Sat May 09, 2020 9:04 am
The daytime, low and high beam indicators no longer work (though the actual lights function fine). Carly now shows problems with DTC and the instrument cluster.
I am going to try the coding again. I found another NCS profile file online which is named "Expertenmodus (Werkseinstellung)", just like in your guide, so hopefully it works better. I also updated the "SP Daten" via "BMW Coding Tools", something which I didn't do before (as it wasn't an actual step in the guide).
AnubisZed
Post by AnubisZed » Sat May 09, 2020 9:37 am
vld wrote: Sat May 09, 2020 9:21 am
The daytime, low and high beam indicators no longer work (though the actual lights function fine). The Blue high beam not illuminating?! Carly now shows problems with DTC and the instrument cluster.
I am going to try the coding again. I found another NCS profile file online which is named "Expertenmodus (Werkseinstellung)", just like in your guide, so hopefully it works better.Yeah that'sthe one
I also updated the "SP Daten" via "BMW Coding Tools", something which I didn't do before (as it wasn't an actual step in the guide).It'son the first page, telling where to find it along with a link of how to install them. This is not a guide of how to set up NCSExpert, it'sa guide to install cruise control, which is why the link was put there
See responses above.
If it doesn't work with the new profile then I'm thinking it may be a faulty set of stalks.
Dave
vld
Post by vld » Sat May 09, 2020 11:29 am
After redoing the process, the blue (high beam) indicator now works fine. Was there an indicator for the low beam or daylight running light to start with? (Not that I would need one, as I keep the short beam always on.)
AnubisZed
Post by AnubisZed » Sat May 09, 2020 11:34 am
vld wrote: Sat May 09, 2020 11:29 am After redoing the process, the blue (high beam) indicator now works fine. Was there an indicator for the low beam or daylight running light to start with? (Not that I would need one, as I keep the short beam always on.)
No just the blue high beam indication.
It looks like the link has been changed so I'll have to update the how-to and re-upload the profiles again.
Glad yours is working now. :thumbsup:
Dave
vld
Post by vld » Sun May 10, 2020 7:07 am
Thank you very much for the guide, it's so nice to have this feature. I can't believe BMW didn't fit this as a standard option given how small the hardware difference is.
Tarzan
Post by Tarzan » Wed May 13, 2020 9:08 am
I would like to clarify.
For those like me who have a heated steering wheel, the part you buy must have the blue connector as in the photo.
This is the one I bought
