BMW E85 and E86 Wheels and Tyres Thread
Thank you, here is picture:
- 9DFCC850-60F7-4A10-ABBC-FFE3F002A5D5.png (488.74 KiB) Viewed 3380 times
- Panta Rhei
Thank you!
Those alloys are flawless
- M@_
I didn’t think these would fit based on other peoples comments on offset.
Style 42 17x8 et 20. 225/45/17 front 245/40/17 rear
Stock height. No rubbing that I’ve noticed.
2003 3.0i
Here's what I have on my 2004 e85 Z4.
M Parallel - Silver Painted With Polished Face
18"x9.5" – front alloy (I think?)
225/40/18 – front tires
18"x9.5" – rear alloy
255/35/18 – rear tires
Tires Purchase link:
https://www.tirerack.com/tires/tires.js ... toModClar=
18" 313's from a 1 series, 7.5" ET49 fronts, 8.5" ET52 rears. The fronts were noticeably tucked in compared to the 108's so I'm running 16mm Forge spacers all round.
- Image.jpeg (181.11 KiB) Viewed 2138 times
Does anyone know if BMW style 230 will fit an E86 coupe?
Front tyres being 235/35/19 and rears 265/30/19
E86 Si Auto Coupe in Ruby Black.
- Argyll Andy
Hi AnilS
I remembered this post as I think these wheels are lovely.
May not be much help as Andra doesn’t mention tyre size but they went on his E85 ok so presuming the same fit for your E86?? HTH
viewtopic.php?t=121423&hilit=230
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
Thanks Andy. Checked the link and they look great. My CSLs have gone so I may look further at 230s but I'm fully expecting to sell my car this so I'll ponder.Argyll Andy wrote: ↑Sat Feb 25, 2023 1:56 pmHi AnilS
Thanks again.
230s should fit fine.
Et37 offset at the front is equivalent to running a 10mm spacer with a typical (108, MV2) wheel
Et39 at the rear plus an extra half inch of wheel is equivalent to running a 17.4mm spacer, but is still considerably less aggressive than a 224’s et30, which many members run.
2003 Maldives Blue 3.0i auto
Thanks @zedebee.
Would a 265 section tyre run with that offset?
Should be ok at the rear assuming a 30 profile tyre (it’s a 19” wheel).
Thanks again.
These were on an E92 so I'm guessing they'll probably be RFT?
If so, it'll be unbearable.
- M@_
- inkey$
Temporary gloss black MV2's on Black Sapphire roadster while my 107s are being powdercoated. Maybe useful for those thinking of such a look.
Previously: Z3R 2.8 • E46 330i • Z4R 3.0 • Z4///MC • E90 335i • Z4///MR • Z3///MC 'Breadvan' • Z3R 2.8 • E30 325i R • Z4C • Z4R 3.0
- Dubbedown
As much as I love my Style 32’s, they unfortunately do not clear my BBK without a thick spacer on front. So I decided to search for another set of aggressive offset OEM wheels. Considered the usual suspects (e.g. style 260) but actually found something even more unique.
Picked up a mint set of style 641’s, which are the factory winter wheel recommendations for the F8x m3/4. Because it’s a winter setup, the rims are slightly narrower than the standard F8x M wheels, which makes it an even better fit for the E85/86 M models. Slightest rub on full lock but pulling the camber pin should alleviate that.
Specs are 19x8.5 et 27, 19x9.0 et29. Tires are 225/40 and 255/35-19.
Follow latest mods on Imolarot_S54 M Coupe OEM+
