BMW E85 and E86 Wheels and Tyres Thread
Alloy wheels and tyre discussion
Nasurock658
Post by Nasurock658 » Thu Jan 06, 2022 6:48 am
Just Awesome Post Buddy . Very Informative Thanks to share With us :) :) :)
TeeBee
Post by TeeBee » Mon Feb 07, 2022 2:52 pm
Hi folks. New boy on here.
I’ve a 2007 E85 2.5si SE running the original 16” rims & runflats.
The runflats need to go to smooth the ride, so it could be the time to change up to 17”.
Any thoughts, recommendations, or things to avoid?
Panta Rhei
Post by Panta Rhei » Wed Feb 09, 2022 4:41 pm
I'd suggest styling 105. Why? Because they are the only 17" OE staggered E85/E86 option and 255 tyre on the rear looks really good. It needs it. Also easy to clean.
8x17 225/45
8,5x17 255/40
Can't go wrong with Michelin PS4 or PS4S :thumbsup:
Consider Eibachs in the future + spacers 20 mm rear plus 5 mm front.
TeeBee
Post by TeeBee » Wed Feb 09, 2022 10:39 pm
Thanks Panta
Plumby321
Post by Plumby321 » Mon May 23, 2022 6:10 pm
Good Evening all,
Looking to change my MV2 18”s to something like an Apex Arc 8 or Strom STR2 the sizing of these is as below would these fit on my 3.0si e86 please tyre wise (straight tyre swap from my current) and also fit the car iteslf?
Size:
18"
Colour:
Quartz Silver
PCD:
5x120
FRONT AXLE (x2 Wheels):
18x8.5 ET20
REAR AXLE (x2 Wheels):
18x10 ET20
Many thanks
Zedebee
Post by Zedebee » Mon May 23, 2022 6:47 pm
Plumby321 wrote: Mon May 23, 2022 6:10 pm Good Evening all,
Size:
18"
Colour:
Quartz Silver
PCD:
5x120
18x8.5 ET20
18x10 ET20
Many thanks
The rears will be 5cm more “outboard” than standard, i.e. about 3cm beyond the bodywork. Ok if you want the Carlos Fandango look 🤔
2003 Maldives Blue 3.0i auto
Zedebee
Post by Zedebee » Mon May 23, 2022 6:50 pm
p.s. check it out yourself on willtheyfit.com
Standard rears are 18 x 8.5 et50
TheDan
Post by TheDan » Mon May 23, 2022 6:55 pm
Front Axle:
Standard: 18x8J ET47
New: 18x8.5J ET20
Tyre: 225x40xR18
The 225mm tyre is the minimum width you can use on an 8.5J wide wheel.
In terms of size, the wheel will poke out 33.4mm more than before. This is far too much and will stick out of the arches and almost definitely rub when turning the wheel.
Rear Axle:
Standard: 18x8.5J ET50
New: 18x10J ET20
Tyre: 255x35xR18
The 255mm tyre is the minimum width you can use on an 10J wide wheel.
In terms of size, the wheel will poke out 49.1mm more than before. This is far too much and will stick out of the arches.
Now to be helpful :D
I am also looking for some ARC-8s soon (switching from MV2) and the best sizes in my opinion are as follows:
Front Axle:
18x8.5J ET42
Rear Axle:
18x9J ET45
These sizes give a front and rear poke of 11.4mm more than before. This is good for me as I am running 12mm spacers front and rear so it will match those. Plus with this setup you have the option of fitting more spacer. Its quite difficult to fit negative spacers :P
Plumby321
Post by Plumby321 » Mon May 23, 2022 7:39 pm
Thanks All super helpful it makes sense now!
So in short none of the strom str2s will fit our cars?
https://stromwheels.co.uk/product/strom-str2/
Panta Rhei
Post by Panta Rhei » Mon May 23, 2022 8:46 pm
None. ET is too aggressive. If you want CSL replicas (styling 127/163 plus 359) consider:
avus racing
vmr vb3 (v703)
riva dtm
atomic csl
Avant Garde M359
sportline 8s
apex arc-8
wsp italy
atomic csl
VEEMANN VC359
CB MODEL:BM10
TheDan
Post by TheDan » Mon May 23, 2022 9:34 pm
Panta Rhei wrote: Mon May 23, 2022 8:46 pm None. ET is too aggressive. If you want CSL replicas (styling 127/163 plus 359) consider:
avus racing
vmr vb3 (v703)
riva dtm
atomic csl
Avant Garde M359
sportline 8s
apex arc-8
wsp italy
atomic csl
VEEMANN VC359
CB MODEL:BM10
This is a really useful list, thanks Panta Rhei!
Plumby321
Post by Plumby321 » Mon May 23, 2022 9:44 pm
avus racing
vmr vb3 (v703)
riva dtm
atomic csl
Avant Garde M359
sportline 8s
apex arc-8
wsp italy
atomic csl
VEEMANN VC359
CB MODEL:BM10
Cheers mate so looking like Veemann or Riva will be the right price bracket and look. do you have any feedback on either of the reference fitment and quality. I do like the concaved look but still needs to be usable as will be tracked from time to time. I am running BC Coilovers and will run 18” wheels
Panta Rhei
Post by Panta Rhei » Mon May 23, 2022 9:54 pm
G'day mate,
You will most likely need to visit manufacturer homepage and find desired wheel and then check if they fit.
Fronts:
8J ET 35-50
8,5 ET 40-45
Rears:
8,5 ET 30-50
9 ET 35-45
OFC this measurements are approx and Michelin 225 can be Goodyear 235 :|
Fronts in Z4 are pain in the arse, because of wheel arch shape behind side marker.
Plumby321
Post by Plumby321 » Wed May 25, 2022 2:58 pm
Hi All,
Following on from this I have narrowed the wheels I’d like down to the below:
Riva DTM 18” which are
Front 8” ET 34
Rear 8.5” ET 37
£570
Or
Veemann VC359 18”
Front 8.5” ET35
Rear 9.5” ET45
£799
I want a nice looking good quality wheel. I am lowered although not crazy on BC adjustables and and would like to be able to use car for some track use so looking for best looking without rubbing.
Any advice for which of the above would be best please?
Many thanks
Pazza
Post by Pazza » Wed Jun 22, 2022 9:51 pm
Just acquired my first e86 with 108 style 18” wheels with Bridgestone Potenza RE050A run flats. They still have around 7-8mm tread on all the tyres but I have never been a fan of run flats and want a better ride quality. I was thinking of changing them once they are due for replacement but based on my light use that could be a while.
Is there a recommended non run flat tyre for these 108 style wheels. I see many recommend the Michelin PS4, but do other tyres match this wheel better.
Any thoughts?
2008 BMW e86 Z4 Coupe Si Sport, Titanium Silver, Auto - loving it!
2005 Mini R50 Park Lane JCW Royal Grey
2011 Mercedes W204 C250 Iridium Silver Auto - Gone
2010 BMW e90 325d M Sport Space Grey Auto - Gone
