Bradz Z4MC Project thread, Back on the road!
- bradz
I bought this car a few months back...
Modifications so far...
Compomotive MO6 18x8 18x9 with MPSS
Front BMW Performance 6pots with ds2500 & HEL lines
Hayward & Scott exhaust - Now sold
Its a very clean car on top, but a few of the components are a little corroded on the underside as the car has been in storage for 4-5 years.
It started with the input seal of the diff weeping...
So I have decided to do a bit of a clean up over the winter.
Plans are:
KW v3's - On order from Awesome GTI
Strip clean and powder coat rear sub frame
New Kunifer Brake lines
Superpro Rear sub frame bushes & RTAB
Powerflex rear arms - Purchased
Replace every suspension joint with Lemforder/BMW
H&R M3 Anti roll bar kit.
New rear wheel bearings as arms will be powdercoated
Diff to be split, blasted and coated with new seals clutch pack & Bearings checked - With specialist
Porsche Rear calipers - With custom-brake-calipers.co.uk being painted Phoenix yellow to match fronts
Full super sprint exhaust
I'm sure I have missed a few bits.
Plans are:
- IMG-20171026-WA0002.jpeg (158.92 KiB) Viewed 2557 times
- IMG-20171025-WA0017.jpeg (161.45 KiB) Viewed 2558 times
- 20171022_142915.jpg (416.16 KiB) Viewed 2558 times
- IMG-20170920-WA0000.jpeg (212.13 KiB) Viewed 2558 times
Z4M Coupe, E92 M3, E46 M3 Track car
- tomscott
- bradz
Small update,
Got the rear sub frame all split and ready to be powder coated,
Purchased a bearing press to pull all the bearings and bushes, although I did need to borrow a friends press to get the hubs out.
Purchased brand new brake lines from BMW - These come in a straight length and are not bent to shape unfortunately.
a few goodies have arrived this week, Superpro Sub frame bushes & RTAB, Powerflex Black Diff bushes & Adjustable arms, E46 M3 H&R roll bars.
- 20171104_151457[1].jpg (339.46 KiB) Viewed 2470 times
- 20171104_151211[1].jpg (293.65 KiB) Viewed 2470 times
- TomK
Nice work, keep us posted please. It's definitely something I'd like to do one day, drop the rear (and front) ends and clean them all up, probably take me a lot longer than you to get it done though!bradz wrote: ↑Sat Nov 04, 2017 4:26 pm Small update,
Disappointing the BMW lines are not pre-bent, do they advise in TIS best practice for fitting these?
Interesting your driver's side stone guard looks new, that's a fairly big job to get to right?
Haha mate I know you said you were going to work on your new toy but bugger me hahah
Going to be sweet as
- Machine monkey
I did this with my car a few years ago. Increadably rewarding to know that it’s all sorted and tip top order. I didn’t go the brake lines. As mine where good. Great work buddy
You sparkies earn too much money
Get your shells done aswel ad.
Last edited by dannytheduck1985 on Sun Nov 05, 2017 10:07 pm, edited 1 time in total.
84’ E28 Alpina B9
83’ VW B2 Passat CL
90’ Mercedes 300E-24
90’ Vauxhall Carlton GSI 3000 24V manual
85’ Opel Ascona Cabriolet
83’ VW B2 Passat CL
- Beedub
in a single garage as well..... serious DIYer at work here, thats not easy stuff!! impressive!!
Ad, may be worth having the parts under the car raptor coated instead of powder coating. Powder coating can chip off but raptor is a poly urethane based under sealbradz wrote: ↑Sat Nov 04, 2017 4:26 pm Small update,
84’ E28 Alpina B9
83’ VW B2 Passat CL
83’ VW B2 Passat CL
- MrPT
Totally. Nothing like stripping something back and getting your eyes on everything.Machine monkey wrote: ↑Sun Nov 05, 2017 9:21 pm Increadably rewarding to know that it’s all sorted and tip top order.
Tempted by a higher final drive ratio?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Machine monkey
I did mine in my garage and on my drive way. Never again it’s not impressive I have vowed to never again lie under a car and swear st it. My friend Chris was of the same opinion. That’s why we brought a 2 post lift! Best £1200 you will ever spend I’d you work on cars.
- Woots
- Machine monkey
I haven’t ever bothered looking into changing the final drive. As I imagine it to be quite a pricy thing to do.MrPT wrote: ↑Sun Nov 05, 2017 11:12 pmTotally. Nothing like stripping something back and getting your eyes on everything.Machine monkey wrote: ↑Sun Nov 05, 2017 9:21 pm Increadably rewarding to know that it’s all sorted and tip top order.
- Beedub
Machine monkey wrote: ↑Mon Nov 06, 2017 9:33 amI did mine in my garage and on my drive way. Never again it’s not impressive I have vowed to never again lie under a car and swear st it. My friend Chris was of the same opinion. That’s why we brought a 2 post lift! Best £1200 you will ever spend I’d you work on cars.
not everyone has the space for a lift and can afford to drop 1200 quid on one..... if we could, everyone would have a lift without doubt!
- Machine monkey
You can get some really cool single garage ones buddy.Beedub wrote: ↑Mon Nov 06, 2017 2:29 pmMachine monkey wrote: ↑Mon Nov 06, 2017 9:33 amI did mine in my garage and on my drive way. Never again it’s not impressive I have vowed to never again lie under a car and swear st it. My friend Chris was of the same opinion. That’s why we brought a 2 post lift! Best £1200 you will ever spend I’d you work on cars.
And trust me I am not made of money. I guess it’s a question of how much you would use it. We use ours all the time i share it with a friend. And we have built 2 cars ourselves. We ar4e lucky to have a mix of skills and experience. So we can do most things and not have to pay tuners or garages to do jobs for us. So it’s been a big saving really.
I would say i saved my £600 in building my exhaust and fitting my own clutch on the ramp.
