Trouble with images in Signature
BeardyJon
Post by BeardyJon » Thu Oct 19, 2017 2:18 pm
I'm having problems updating my signature - I've resized a photo to be 150 pixels in height, which is the maximum size, and the forum won't allow me to update my signature with the photo saying its too big.
Can you help?
I'm trying to add this one to my already existing signature:
2012 E89 sDrive20i M Sport Celtic Tuning Stage 3 Remap
2008 E86 Z4 M Sport 2.0i - Gone
2003 E46 316ti M Sport - Gone
Marlon
Post by Marlon » Thu Oct 19, 2017 2:26 pm
BeardyJon wrote: Thu Oct 19, 2017 2:18 pm I'm having problems updating my signature - I've resized a photo to be 150 pixels in height, which is the maximum size, and the forum won't allow me to update my signature with the photo saying its too big.
Can you help?
The sig also has a maximum width of 600px - you are probably exceeding that
Gone: 3.0si 2008 E85
911 997 Carrera S
BeardyJon
Post by BeardyJon » Thu Oct 19, 2017 6:28 pm
The image is only 412 px wide, so that can't be it.
Wondermike
Moderator
Moderator
Post by Wondermike » Thu Oct 19, 2017 6:34 pm
The entire signature including text shouldn’t exceed 150px high.
WLH
Post by WLH » Thu Oct 19, 2017 6:52 pm
There is also limit on the size of the file in KB. I have optimized the 2 files for the web and either file should now work. Note the picture below will appear much larger than their actual size. Just do a copy or save as to your computer and they should work just fine. If they don't let me know.
2007 ///M Roadster - My Zed's - Member ZSCCA - ///M Registry - My Videos
Pbondar
Post by Pbondar » Mon Nov 20, 2017 3:16 pm
I get an error message saying unable to determmine size and refusing to load picture, size and dims are all A OK
I see in php support its a common fault caused by repeated upgrades rather than clean install..
tried various hosting sites to no avail..pls advise
BeardyJon
Post by BeardyJon » Wed Jan 03, 2018 11:17 pm
Still having problems - tried downloading the images above and they're saving as 1200x489px so having to resize, and still having same error messages.
Wondermike
Moderator
Moderator
Post by Wondermike » Thu Jan 04, 2018 12:05 am
You can only use one of them not both, if that’s what you’re trying to do.
BeardyJon
Post by BeardyJon » Thu Jan 04, 2018 11:02 am
neither work. Even when I edit only the text and use the current one it throws an error message.
Attilio
Post by Attilio » Thu Jan 04, 2018 12:00 pm
Have you tried to "merge" those images into a new one with the two original ones side by side?
Happy to give it a go myself if you send me the images...maybe there is something that "stores" the old values and causes the error...
Z4M Coupe, Interlagos blue, black leather, piano black, stubby, OEM CSLs, evolve intake, cup holders...pretty much stock
2019 Toyota Corolla hybrid 2.0L - new daily drive
BeardyJon
Post by BeardyJon » Mon Jan 08, 2018 5:10 pm
I don't think the error is related to the images. Even images which fit all requirements are throwing up an error telling me they're too big. Even using only one. If I just try to re-use the existing one in my sig, it fails. So I doubt that doing anything to the images is going help. Seems like its a software error with the forum.
Buckz
Post by Buckz » Mon Jan 08, 2018 5:14 pm
put the below in your signature.. will that work?
Code: Select all
[img]http://image.ibb.co/jfUARm/oSNlB.jpg[/img]
sample text[/url]
BeardyJon
Post by BeardyJon » Mon Jan 08, 2018 7:00 pm
Nope. Still tells me that images can only be 150px high
Buckz
Post by Buckz » Mon Jan 08, 2018 7:07 pm
Weird. Try a different browser that you haven't used before on this forum.
BeardyJon
Post by BeardyJon » Tue Jan 09, 2018 6:57 pm
Tried with Chrome (was using Safari before) still get the same error.
