Electric Water Pump Failure - Poll
Has your electric water pump failed (N52 engines - facelift)?
Yes
34
27%
Not yet
91
73%
Total votes: 125
dgmx5
Post by dgmx5 » Mon Nov 23, 2020 4:03 pm
Smartbear wrote: Mon Nov 23, 2020 2:58 pm
Chickendippers wrote: Mon Nov 23, 2020 1:52 pm Around 120k and cost £1000 to fit at the dealer. Managed to limp it to the dealer which was only 5 miles away thankfully. it was on my list of things to do with my indy but was waiting for a cheaper insp1 to do at the same time. In the end i did an Insp2 followed 2x weeks later by the water pump. Lean times.
You paid a grand to get the water pump fitted? Please tell me that’s a mistake.
Probably not. I did get Sopers Lincoln to quote and prices below are RRP for OEM parts (with Soper's forum discount in brackets):
Water Pump £508.34 + vat (£549.01 incl VAT)
Screws £5.86 + vat (£6.34 incl VAT) [these come included with the Pierburg pattern part]
Thermostat £92.24 + vat (£99.22 incl VAT)
So just in parts alone, if you replace pump and thermostat at a non-forum friendly dealer it is £725.
Mr Tidy
Post by Mr Tidy » Mon Nov 23, 2020 9:25 pm
Just don't buy from BMW!
When mine died in 2015 my Indy paid over £500 for a pump from BMW. :o When the pump died on my 325i in 2018 he bought an OE Pierburg one elsewhere and charged me around £300 for the same part. :D
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
dgmx5
Post by dgmx5 » Tue Nov 24, 2020 6:24 am
Mr Tidy wrote: Mon Nov 23, 2020 9:25 pm Just don't buy from BMW!
Indeed. Bought the Pierburg pump (11517586925, £249.59, comes with the one time use only bolts with it) and Mahle Behr TM1497 thermostat (£58.99, plastic unlike the original metal one) from bmwmotormec on ebay. £308.58 vs £725 is a lot better and I can see plenty on here have got better prices than that too.
Chickendippers
Post by Chickendippers » Tue Nov 24, 2020 9:17 am
No mistake. It wouldn't have been much cheaper at the Indy I use either. Sure the pump is a couple of hundred quid but it is quite awkward to get to - hence the labour. I was expecting it to cost that much so it wasn't too much of a shock (only to the wallet).
58 plate E86, Titan Silver - gone but not forgotten
ph001
Post by ph001 » Tue Nov 24, 2020 10:26 am
Chickendippers wrote: Tue Nov 24, 2020 9:17 am No mistake. It wouldn't have been much cheaper at the Indy I use either. Sure the pump is a couple of hundred quid but it is quite awkward to get to - hence the labour. I was expecting it to cost that much so it wasn't too much of a shock (only to the wallet).
It's very easy to get to on the Z - nothing much needs removing at all for access apart from the undertray. Much easier than it is on the 3 series. Even the 15 min bleed afterwards is fully automatic while the mechanic goes off and has a cup of tea.
Smartbear
Post by Smartbear » Tue Nov 24, 2020 11:12 am
ph001 wrote: Tue Nov 24, 2020 10:26 am
I think me & my nephew changed the pump on my 3.0si in under an hour, it’s a quick & easy job :?
e85 3.0si sold
Chickendippers
Post by Chickendippers » Wed Nov 25, 2020 10:54 am
Smartbear wrote: Tue Nov 24, 2020 11:12 am
:o :o :o
Oh well - it's only money......
enuff_zed
Post by enuff_zed » Wed Nov 25, 2020 11:00 am
Chickendippers wrote: Wed Nov 25, 2020 10:54 am
ph001 wrote: Tue Nov 24, 2020 10:26 am It's very easy to get to on the Z - nothing much needs removing at all for access apart from the undertray. Much easier than it is on the 3 series. Even the 15 min bleed afterwards is fully automatic while the mechanic goes off and has a cup of tea.
:o :o :o
Well at least, now you've joined the forum, you can ask about these jobs first and go to the garage armed with the info. May save you a few quid later on. Or, depending on your confidence with spanners, read up and do the work yourself.
That's the beauty of a forum really; always someone who's done it before and can guide you.
HQ of 'Norfolk Zed Rescue'.
Joycey
Post by Joycey » Mon Jul 18, 2022 7:05 pm
Mine finally failed. 150k miles and god knows how many track days now. Well impressed, swapped pump and thermostat for OE parts this morning.
chalcid
Post by chalcid » Tue Jul 26, 2022 1:40 pm
Just to add to this - my water pump has just started to go on my 2008 2.5i sport c at 77k. Thanks to previous reading on the forum it was quickly identifiable before any overheating was experienced! Symptom was a quick spike in temp followed by a sharp drop back down to normal as the pump was working on/off. The pump did appear to be working when I ran the bleed procedure with the expansion cap off to have a look. Handily, I was just down the road from my local garage so just slowly rolled it over to get it checked and there were a few codes from the pump so it's in for a replacement. Cheers!
