I'll defer to Dave in the creation of a loom from an E90... or from scratch -- that's beyond my plug and play skill!
![Surprised :o](./images/smilies/shocked.gif)
Thanks Dave. I’ve ordered used oem sensors for £15 each which hopefully will be fine. I was looking at a E88 loom but I’ll look at the E90 next.
No I was referring to the cheap Chinese copies from places like Aliexpress.Christopher72 wrote: ↑Wed Jun 14, 2023 3:12 pm Dave, when you refer to cheap copies.. are you referring to non-BMW OEM or $2 chinese noname? https://www.ecstuning.com/Search/SiteSearch/E89_PDC/ There are several more affordable versions at this wellknown vendor in Ohio.
That price is crazy. Your videos must be increasing the demand
I list everything in the video, but I used E91 looms and modified them.SwissTone wrote: ↑Mon Aug 14, 2023 9:31 am Hi Dave
Yet another project I've decided to jump into
Like some have mentioned finding the official retro fit kit seems impossible atm, unless I've not looked properly?
If there's no stock anywhere then I guess the other option is the E9x looms you mention, could you enlighten me on which ones would work for both the front and rear and what would need doing to them to make them work in the E89.
fyi I have the sensors and control module unit, plus the front mounting brackets (these seem super expensive for a bit of modded plastic)
There's that! Thanks for sharing your wisdom. I can also now brag about doing a mod you will never approach... Painted marker reflectors. It's nice to get that orange off the side of the bumper cover.
If there's any consolation, Swiss, the official retrofit wire looms require connector pin assembly, which is likely as intimidating as reusing another model (e91). It's probably left unfinished on the end to make traversing the grommets in the front and back easier than having the big blocky connector already terminating the wire and having to be removed to thread through.
