Groan from steering
Groan from steering
My issue seems to have been solved. I hv no idea how. It just seemed to go away itself after I lubed loads of times. Maybe it just needed time to work its way in.
Groan from steering
I'm up the M40 by junction 5 , we can have a go at spraying the joints to see if it works, it did on my car.TIGERPOOL87 wrote: ↑Sat Apr 22, 2017 4:27 pm Is anyone in the west london area that could have a look for me? I have the same issue. Willing to pay of course, but not the extortionate prices the garages have quoted.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Groan from steering
Just sent you a private message. Thanksfirebobby wrote: ↑Sun Apr 23, 2017 11:28 pmI'm up the M40 by junction 5 , we can have a go at spraying the joints to see if it works, it did on my car.TIGERPOOL87 wrote: ↑Sat Apr 22, 2017 4:27 pm Is anyone in the west london area that could have a look for me? I have the same issue. Willing to pay of course, but not the extortionate prices the garages have quoted.
- BigDaddy
Groan from steering
I’m thinking of lubing my steering. It doesn’t groan but is a bit heavy. Not sure if it’s normal for these cars or not to be honest.
Either way I’ve got some lithium grease and was going to spray that on the column and where it enters the rack. Didn’t want to use wd40 as that doesn’t give me confidence it will lubricate it long term. Is lithium grease a better bet?
2004 E85 3.0 Sterling Grey
Online
Groan from steering
I used Bmw power steering rack grease and when I did the steering rack it seemed to match the grease that was in there, I also greased the steering column uj's and sprayed ptfe spray on the plastic collar where the column comes through the bulkhead this cured my groaning steering.
If your steering is heavy tho have a look at the various sticky steering threads on here and see if maybe that is your problem.
04 2.2i Sapphire Black Roadster
- enuff_zed
Groan from steering
Tornado axle grease worked for me.
Online
Groan from steering
If it's good enough for one of the best fighter jets ever made then I'm sure it's good enough for one of the best roadsters too
- enuff_zed
Groan from steering
Online
Groan from steering
Sorry you'll have to excuse my ignorance of calling it a fighter jet, just googled it, multi role combat aircraft it says, saw a gr4 go through the mach loop just before it retired very impressive
- enuff_zed
Groan from steering
When my wife says I’m not listening I simply blame night shifts, sitting under a Tonka doing engine installation runs in full reheat about 6 feet from my head, simply because it was the only warm place to be.
