BMW E89 Audio Systems and Upgrades
LOL at 'yoof'. Haven't been called that for quite a few decades now...but hey i'll take it!
My E89 is a 2015 sDrive 20i MSport with 8AT. It has the iDrive / satNav/ bluetooth etc - all standard. but maybe relevant in terms of audio.
The sum total of my upgrades to date have been a remap and......a stubby
I don't really have any specific expectations of this speaker upgrade other than it being sufficiently better to be worth the cost & effort (a bit subjective of course) and I might be inclined to abandon the idea altogether if its only going to be a step on a long and expensive journey.
Well I think the Eton type speakers are a quick win..everything after that is harder work..
You’re car will have the BMW Active Sound Design synthetic brum brum sound injected into the speakers...see ASD on the Forum for more on that..
The stubby is a retrograde step but heh..
Well... I was stubborn and did'n buy proper speakers and now I have 2 days since I am 3d printing adapter rings. Done the rear, and now I am testing the some for the fronts, before printing in ABS.
Also spent entirely day rewiring all the speakers to the amp, that I put it behind passenger seat.
Tomorrow another noico sound deadening batch to finish the doors.
I've done an edit /update to the orginal post in light of some additional bedtime reading..nothing major..
- Wolter
Hi guys, decided to upgrade my hifi system as well and started with installing a couple of Herz SP 165.1’s behind the kick panels. Since I’m using the old speaker housing to lock the new ones in place I thought I might as well try to transplant the female harness connectors from the old speakers. See the result below.
Soldered the old harness pins to the Herz connectors. Locked the harness in place with some superglue (just to be safe).
Maybe not the best looking solution but works like a charm.
- BFD6EB6C-BDF7-4CEC-A244-B8D5994EE282.jpeg (135.23 KiB) Viewed 994 times
- C046D5B1-7F23-4944-B181-7FDB31DF45AA.jpeg (124.81 KiB) Viewed 994 times
- 840E2586-FED8-4FEF-AD27-CC3C6AADDB3D.jpeg (156.84 KiB) Viewed 994 times
- 9EA825DB-76D8-47D7-A38D-139A05865FD6.jpeg (118.53 KiB) Viewed 994 times
2010 E89 2.3i Tiefseeblau Metallic
1999 R1100S Marakesh Red
- B21
Good work..when I fit my Audio Fischer Helix Woofers in my 35is in the winter I may plagarise your efforts..Wolter wrote: ↑Fri May 06, 2022 5:48 pm Hi guys, decided to upgrade my hifi system as well and started with installing a couple of Herz SP 165.1’s behind the kick panels. Since I’m using the old speaker housing to lock the new ones in place I thought I might as well try to transplant the female harness connectors from the old speakers. See the result below.
Although they are never ever likely to come out again..
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
Hi adding to the audio queries
I have the BMW Business Speaker Package aka BMW Hi-Fi aka 676 option
Doing the speaker upgrade as many are
I am looking to install the rear centre speaker and tweeter, does anyone know whether this can be wired to the 676 and if so which pins should be used and the cable routing?
- B21
In simple terms you can’t ..there are not enough amplification channels and the internal DSP isn’t configured to do it..birdy_z4 wrote: ↑Tue May 17, 2022 6:05 pm Hi adding to the audio queries
Apart from its fine….
Thanks for the answer
Reading up on amps, the next level up amp on the z4 also appears to be wired differently, is that the case
What’s the best option upgrading to an amp per this thread or the next level BMW Z4 amp?
B21 wrote: ↑Tue May 17, 2022 6:59 pmIn simple terms you can’t ..there are not enough amplification channels and the internal DSP isn’t configured to do it..birdy_z4 wrote: ↑Tue May 17, 2022 6:05 pm Hi adding to the audio queries
- B21
The 677 amp is wired up totally differently…not trivial to implement..IMHO
Your best option is the Audio Fischer Match 7 DSP/amp which is almost plug compatible..see pbondar write up on the issues ..
Or search Match 7 here also..
Of the many threads I have read on the subject of Z4 audio upgrades, this is the gold standard - many thanks.
I have a UK 2016 28i Z4 with the base systems and I am very keen to upgrade it - i.e. replace door speakers, add tweeters, replace footwell woofers, potentially add woofers behind the seats or a single sub in the luggage hatch area, and add an amplifier. The current plan is to go Audison throughout.
I have a few questions and would be very grateful for any answers:
- Is there an elegant way to use the existing speaker wiring from the head unit? I am planning to run the speaker channels from the head-unit straight into a 6-channel amplifier in the boot. Ideally, I can use the existing wiring (with extensions) to go from the amplifier to the door + footwell speakers. Is it up to it? Are there aftermarket off-the shelf wiring hardnesses that might help here?
- Is the best route for wiring to/from the boot under the centre console, or some other path?
- In a car that does not have the woofers behind the seats, is there still a hole for them in the body shell?
- In a car that does not have the hatch from the boot to the cabin, is there still a hole in the body shell?
- Does anyone have any positive experiences of putting an active subwoofer in the recess for the hatch?
If I can work up the courage to do this, I'll share the experience .
Cheers,
-Mark
Cheers,
-Mark
- B21
Each of the 3 audio systems has its own unqiue wiring llom, so you can't plagarise another audio's systems cables..
There are a numbe rof harnesses now offered to allow the 6 speaker system to integrate with a DSP/amp...being an Audio Fischer bigot I'm mostly aware of their versions for their products..but it seems other suppliers are doing similar systems.
Running from front to rear is relatively easy as you can route via the centre tunnel and/or the edges by the door jambs.
There are a couple of access points to get into the boot area so again running from the headunit to a DSP/amp in the boot then back to the headunit to take advanatage of the stock wiring is easy enough.
The body shelll has the mounts for the subwoofers..you either will need to cut some holes and fabricate speaker covers in the rear cabin trim or buy a second iuser version from a 676 or 677 version car.
Personally I'd go for the pukka sunwoofers in the correct positions if you are going that far.
Good woofers with decent DSP/amp provision will make a dramatic difference to lower frequencies.
I've spent a fortune on subwoofers and amps for poor results.
As a coupe ie roof up..its easy to get good audio performance, roof down at 85 mphs its harder work..
Enjoy the journey!
Enjoy the journey!
Much of what you have asked is already covered in my thread: viewtopic.php?t=126024mlippett wrote: ↑Wed Aug 09, 2023 1:08 pm Of the many threads I have read on the subject of Z4 audio upgrades, this is the gold standard - many thanks.
Cheers,
-Mark
You can use the existing factory speaker wires, they are more than capable of handling what you want to do. You can splice off the speaker wires behind the head unit and take it to your amp and from your amp back to the other end of the head unit. B21 has mentioned there are harnesses available to do this but I suspect they cost an arm and a leg and it would be much cheaper to make up your own harness only caveat being cutting into the original wires.
For the cabling I ran mine the same way as the factory along the passenger side door sills / jambs. For the subs the holes are there and the trim panel for the bulkhead has the cutout marked on the back where you can make the holes, again see my thread all info is contained there. I would imagine the hole for the pass through is also there.
I have placed two Kicker shallow mount subs in the bulkhead space where the original factory subs should be and they do a fine job sound great with some deep bass but it's not the type of bass to shake the mirror or windows. For that you need much bigger subs which require much bigger box which is almost an imposibility in this car due to space. Even if you put sub box in the boot (assuming you have the pass through) you are limited by space if you want to keep the functionality of the folding roof.
I was thinking of the downfiring sub box from Kicker with a 10" sub that can sit in the boot neatly and still allow the roof to fold but I am not sure how much more bass it would generate compared to the 2 6.75" subs that I have in the bulkhead already.
Thanks both for your responses.
@B21 thanks for the tip on Audio Fischer, somehow they had passed me by.
@Silverstar a couple more questions if I may - how difficult is it to get the wiring along the passenger side door sills - does the seat need to come out? Is it obvious which cables to hook into from the head unit? I'll follow your lead on the subs - no need for anything in the boot for me.
- B21
AF are a great company ..their DSP tools allow you to create a fabulous , coherent , clear and stable soundstage…some folks really appreciate that..others are happy with ‘stereo’__I’m sure Audison do very similar things..mlippett wrote: ↑Thu Aug 10, 2023 7:23 am Thanks both for your responses.
Enjoy your journey…
