I went for the non m sizes/profiles to keep Speedo factory accurate. No close ups of the wheels but the rim protection is not amazing, 5mm at best. Fronts seem to have a bigger lip for sure. I've scrapped mine already in a tight parking lot so I'll say that it's minimal from my POV.Danderton wrote: ↑Mon Apr 10, 2017 9:38 pm Looking good!
I'm about to order 4 x Goodyear AS3s for my 224 alloys too. They currently have the original 11 year old tyres on and they're M profiles. Am planning on changing to non M profiles.
Can I ask what profiles you went for? 35 and 40 (non M) or 40 and 45 (M profiles)?
Also do you have any closeup pics? I'm interested on seeing the rim protection on the tyres as I've read they're not as protective as AS2s were
Dan
Buckz's Z4 Coupe.
- Buckz
Buckz's Z4 Coupe.
- Steve84N
Buckz's Z4 Coupe.
AS3s are a more rounded tyre and have about 20mm less tread width touching the road for a given size. I would suggest 245/40/18 and 235/40/18. You don't need 255 on the rear so 245 helps the front turn in better with the 40 profile giving a much more accurate speedo. Bringing the front up by 10mm gets close to square for less understeer and with a difference of just 10mm front to back that's far more in keeping with a difference in wheel width of 12.7mm. That would put the rear ever so slightly higher than the front due to tyre sidewalls but a small amount of rake is no bad thing. This is what I have apart from the 235 which I will switch to soon as I'm still wearing out a 225/40/18. I'm also going to try the Michelin PS4 as I've had too many F1s that cause the steering to be off centre despite good alignment.
C63 AMG Estate 6208cc
- Danderton
Buckz's Z4 Coupe.
Thanks for the advice guys
Dan
Dan
Model: Sterling Grey 3.0i Z4 Roadster
Upgrades: M Steering Wheel : ZHP : 224 Alloys : Black Kidneys : Clear Repeaters : Pioneer X580DAB : Stubby
- Buckz
Buckz's Z4 Coupe.
interesting, I find no issues with steering on my AS3's.. can keep hands off the wheel at 70mph on a flat motorway for e.g.Steve84N wrote: ↑Tue Apr 11, 2017 7:48 am AS3s are a more rounded tyre and have about 20mm less tread width touching the road for a given size. I would suggest 245/40/18 and 235/40/18. You don't need 255 on the rear so 245 helps the front turn in better with the 40 profile giving a much more accurate speedo. Bringing the front up by 10mm gets close to square for less understeer and with a difference of just 10mm front to back that's far more in keeping with a difference in wheel width of 12.7mm. That would put the rear ever so slightly higher than the front due to tyre sidewalls but a small amount of rake is no bad thing. This is what I have apart from the 235 which I will switch to soon as I'm still wearing out a 225/40/18. I'm also going to try the Michelin PS4 as I've had too many F1s that cause the steering to be off centre despite good alignment.
- Steve84N
Buckz's Z4 Coupe.
I have a problem on our 330 e91 with AS3, it goes straight if you let go of the wheel but to go straight the wheel is off centre. I've been back to check the toe and it's fine plus it occurred after I swapped those tyres onto it. They are getting made in cheap countries now like Poland where they used to be Germany every time. Still a good tyre but having used them for 10 years it's time to try something new.
- Buckz
Buckz's Z4 Coupe.
weird! doesn't sound like tyres to me but I'm not an expert I have no issues with them so I guess it depends on the car, grip/comfort wise I find them great! compared to the previous falken fk453's which were half the tyre these are.Steve84N wrote: ↑Tue Apr 11, 2017 12:10 pm I have a problem on our 330 e91 with AS3, it goes straight if you let go of the wheel but to go straight the wheel is off centre. I've been back to check the toe and it's fine plus it occurred after I swapped those tyres onto it. They are getting made in cheap countries now like Poland where they used to be Germany every time. Still a good tyre but having used them for 10 years it's time to try something new.
- Steve84N
Buckz's Z4 Coupe.
Tyres can want to track left or right even when pointed straight ahead due to imperfections in construction. There is a Hunter machine called the Road Force Balancer that measures the lateral push as well as the usual weight balancing but they are rare to find.
OnlineEd Doe
Buckz's Z4 Coupe.
Or your garage that did the alignment only adjusted one track rod end, so whilst the wheels line up the steering wheel is not centred, which can also cause the electric steering to fight itself... Just a thought....
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, Supersprint, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- Steve84N
Buckz's Z4 Coupe.
Thanks Ed, I'm aware of that problem and the chap I use doesn't shortcut it. All he does is alignments. It's on the 330 so hydraulic steering (pre LCI) but I also could never get my Z4 steering straight until I swapped out some F1s for new ones.
- Buckz
- Buckz
- dhobbs
Buckz's Z4 Coupe.
How do they repair the dents? Do they need access behind the panel?
I have two small ones on the passenger door and it bugs me. Missus can't see them but I can.
Oh, car looking great by the way
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
- Buckz
Buckz's Z4 Coupe.
Yeah, this guy "fixadent" that's his company name goes in from the other side and massages the dent out with thin metal prongs and then does some minor adjustments from the outside. Took him all of 30 mins to fix those two.
For the boot he went in through the drain hole and for the rear quarter panel through the arch liner. No actual damage to either of those parts.
I'm sure he'll find a way in for the door too haha!
Thanks. Now just need to get the front end resprayed to get it 100%
