LE’s Winter Wheels
Discussing the current generation Z4
q96169we
LE’s Winter Wheels
Post by q96169we » Sat Jan 01, 2022 4:33 pm
sars wrote: Sat Jan 01, 2022 3:43 pm That’s interesting, your G31 obviously also has a 112 PCD, has BMW moved from 120 completely?
All G-series platform cars are using 5*112 PCD. The F-Series cars are the last generation that uses 5*120 PCD.
sars wrote: Sat Jan 01, 2022 3:43 pm what’s the offset on the G31 rears, they look a little inbound
The rear are very inbound instead of a little inbound. Below is the spec comparison. Basically, the rim is 1inch narrower for the G31 which is the main factor to the inbound. ET is actually similar and I doubt the 2mm and 4mm difference are noticeable
G29. vs. G31
Front. 9Jx19 ET32 with 255/35R19 8Jx19 ET30 with 245/40R19
Rear. 10Jx19 ET40 with 275/35R19 9Jx19 ET44 with 275/35R19
sars wrote: Sat Jan 01, 2022 3:43 pm Agree the smaller width makes a difference in noise levels.
As above spec says, the rears are the same size. Fronts are 10mm narrower. I doubt the comfort and noise are caused by this 10mm difference in tyre width. It's more about the tyre compound and design. PSS's performance is much better than the P-Zero 4th gen LS but it's also much harder and louder than the P-Zero.
Roadster_Surrey
LE’s Winter Wheels
Post by Roadster_Surrey » Tue Jan 04, 2022 5:34 pm
sars wrote: Thu Dec 23, 2021 1:36 pm Roadster_Surrey, I'm assuming from you avatar picture that they are Style 799M from the MSport Pro Package, whose/what tyres are you thinking of changing too?
I decided to look for 265/36/19 Conti tyres. From what I read, most places selling them are not sending the tyres from UK, but somewhere from Europe, Holland or Germany.
B21
LE’s Winter Wheels
Post by B21 » Tue Jan 04, 2022 6:00 pm
Roadster_Surrey wrote: Tue Jan 04, 2022 5:34 pm
I think you will find those to be exceptionally rare.. :tumbleweed:
265/35/19 should be more common! :thumbsup: :rofl:
A very modified Atacama Yellow 35is :thumbsup: Previously a slightly less modified Atacama Yellow 20i MSport :thumbsup:
Roadster_Surrey
LE’s Winter Wheels
Post by Roadster_Surrey » Tue Jan 04, 2022 6:02 pm
My bad ;-) Still, 265/35/19 are not popular size.
Roadster_Surrey
LE’s Winter Wheels
Post by Roadster_Surrey » Mon Sep 26, 2022 2:49 pm
After last year's poor performance of Vredestein Wintrac tyres, I bought a pair of Contis to match with existing pair of Contis and that setup is great. With Vredesteins on the rear, car was wandering on the lanes and rear wasn't very stable at higher speeds. Contis on all corners solved the problem. So now, I have 4 x 255/35/19. Tyre shop made a bit of drama when fitting them on the rear, thinking they are too narrow for alloys, but all was ok. Rear wheels don't look pretty with that narrow tyres, not protecting them from kerbs, but I can live with it.
I already did 2000 miles on them in last 10 days and car drives perfectly. Went on alpine passes and even saw some snow fall and -2C.
Schaef
LE’s Winter Wheels
Post by Schaef » Tue Nov 22, 2022 1:10 pm
Yesterday i picked up a set of secondhand styling 800 rims with Hankook winter tyres.
Because the rear tyres had just 3.5mm of profil they will be replaced by Continental wintercontact ts830p friday.
So now the time to clean them end put them in 2 layers of glascoating.
PHOTO-2022-11-21-15-58-53 2.jpg (296.01 KiB) Viewed 552 times
Nanu
LE’s Winter Wheels
Post by Nanu » Fri Nov 25, 2022 9:09 pm
They, like the wheels SARS has, look far too good for only winter wheels. Hope you got a good deal :thumbsup:
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
sars
LE’s Winter Wheels
Post by sars » Sat Nov 26, 2022 5:51 pm
Schaef, Very nice are they staggered layout?
Gorgeous SFR Z4 M40i 8)
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
Schaef
LE’s Winter Wheels
Post by Schaef » Sun Nov 27, 2022 11:08 am
What do you mean by "staggered"?? The size of the tyre's?
sars
LE’s Winter Wheels
Post by sars » Sun Nov 27, 2022 11:25 am
Schaef wrote: Sun Nov 27, 2022 11:08 am What do you mean by "staggered"?? The size of the tyre's?
So the Z4 M40i standard wheel, 800M are 9 x 19 front and 10 x 19 rear, staggered generally refers to one axle having different sized wheels than the other. For winters the BMW recommended set up the Z4 would be 9 x 19 all round with 255/45 r18 (M40i) so was wondering what yours are.
Schaef
LE’s Winter Wheels
Post by Schaef » Sun Nov 27, 2022 12:37 pm
These are the standard M40I wheels, so at the front the 9x19 255/35/19 and at the rear 10x19 275/35/19. I was looking for the 18" wheels but this looks much better and they already where fitted with wintertyres only the rear where just 3mm so these replaced for new Continental 275/35/19 860s tyres.
