E89 power steering issue.
OnlineOwdgit
Thanks Paul, I can't get over how rusty the 8mm undertray bolts are, I had to grind the heads off a few and how bmw bolts the steel v supports directly to the aluminium cross member, lots of corrosion on both of the dissimilar metals. I think I will be priming the mounting bolts and hammoriting the steel v supports and using zinc bolts on the undertray.
Not my idea of fun at 58 scrabbling around on my back correcting bmw's shoddy design.
I like to think I'm an optimist.
2010 Space Grey Z4 E89 N52 3.0 with stuff
2018 VW Arteon 2.0tsi daily workhorse
2020 KTM 1290 Superduke GT
Hi again,
All of those bolts on my Z4 came out fine and it was very clean under thee cover. I see you car is a bit older than mine so things may have had longer to rust and corrode. MY car is a 2013 with just 50k miles.
I am 70, so if I can do so can you, it'll be worth it in the end.
Paul.
Paul.
OnlineOwdgit
Yes it's a bit older but has only done 36k miles, a one owner car but it did spend its life in sunny Scotland. It's just the bolts, v frame and aluminium cross member showing signs of corrosion and other than the undertray bolts the rest is fairly pristine.
Chris
Chris
Have you managed to get the steering motor off?
OnlineOwdgit
Yes, it's with ECU TESTING already.
I just hope that they do find a problem and fix it otherwise it's back to the drawing board
Yes, that’s how I felt, but the did find a fault on mine which was a relief. I hope the find a fault with yours, let me know.
OnlineOwdgit
Took the motor off Sunday afternoon.
It was collected Monday afternoon.
Plenty of updates on the process.
Delivered back this afternoon.
Just fitted it, cleared existing steering errors and now it seems to be working fine with no errors reported.
Thanks to Paul for the advice and ECU TESTING for the quick and professional turnaround.
I'll get around to doing a "How to " when it's not a dry day in the meantime I plan on getting out in it, lockdown allowing.
Really glad of the help and advice from this forum.
Chris
Chris
That’s great to hear Chris, I take it ECU found and cleared a fault. Have a good drive out and I’m sure you won’t hear from that problem again. P
Hi
I realised I never updated this. Just to let everyone know I used ECU testing they resolved the issue, I cannot recommend them enough!
Hi,
Any advice or instructions on how to remove the EPS motor think I have the same issues
Hi just done mine, there is a video on ECU testing web side. But basically remove the under tray two chassis stiffener bars then with the steering on full left lock undo the bolts on the motor belt cover rotate the drive wheel locking rings to line up the cut out with the motor (I found this the hard part) then undo the three motor bolts and remove after removing the electrical connectors
Craig
2011, 23i, Red with Black leather
- Nick9one1
does anyone have a link to the video?
I cant seem to find it.
I presume this is the correct website?
https://www.ecutesting.com/common-fault ... g-problem/
Z4 35i Space Gray, Red Leather
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP
- B21
I believe its this one...the one you listed is for the earlier E85..Nick9one1 wrote: ↑Thu Jan 12, 2023 12:43 pm does anyone have a link to the video?
https://www.ecutesting.com/common-fault ... ack-motor/
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
- Nick9one1
thanks!
I've just taken the old motor off and replaced it with a second hand e89 motor but I still have a fault
The part number on my old motor is 7802 277 247
It looks like the motor is the same part afor the e87, e90/e91. The rack is probably different, but thats not the important bit.
Quite a few motors and racks with the same part number on ebay.
I'm tempted to try another before I send it off for a £400 repair.
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP
Bumping this topic, thinking out loud and connecting it to my own one - viewtopic.php?t=146913
Using the ECUTuning guys to fix your own ecu and motor with a lifetime warranty seems like a good approach. Unfortunately ECUTuning are unable to supply or source the units themselves - and they cannot take your vehicle, remove, refurbish, and refit either. Nor do they offer the services of any local garage to them:
HMMMMMMM.
For future forum users' reference, their description of the typical failure on e89s:we cannot offer that sort of service as we are a testing lab
Although I suspect this service would indeed fix my problem I am literally unsure how to go about using it. Probably need to either invest in a fair few bits and tools, or else need to pay the fees to have it sit with the rack removed in the local indy. Alternatively you buy a used rack and motor (£300) and post to them (£50) for refurb (£525 returned) then sell your own rack I suppose (-£300 back, if you can get it).we typically see these in for Ecu and motor failure, although these units can be prone to the external angle sensor on the rack failing
HMMMMMMM.
2010 E89 35i — turbo boat hooligan - viewtopic.php?t=131886
2008 Ducati 1098S — two wheeled nightmare
