How-To - e89 Cruise Control Retro-fit
How-To articles are in here.
Z4Sparky
Post by Z4Sparky » Sun Mar 24, 2019 5:19 pm
tintoverano wrote: Sun Mar 24, 2019 11:14 am a quick update, all works now :driving:
I'll update.the guide with my findings and send it to you Dave
Any chance of a quick summary of how you fixed the issue as I am undertaking this soon and possibly before the guide is updated.
2010 E89 sDrive 2.3i Alpine White
tintoverano
Post by tintoverano » Sun Mar 24, 2019 5:52 pm
Z4Sparky wrote: Sun Mar 24, 2019 5:19 pm
hi, sure
- I only used Expert mode profile to code all along (see above my request to Dave to send me his profiles)
- since I didn't have FRM I used NFRM to add the Vehicle Order
- after adding VO to CAS and NFRM instead of Process Car I re-coded every ECU listed one by one, somehow it felt that Process Car finished too quickly and also a guy suggested this in a post at another forum
- here exit NCSExper, turn off car, take out key, wait 10+ secs
- and I didn't have to use Tool32 to recalibrate DCS, because I didn't have any fault code at all (I don't know why it was like that, it might be that during my previous coding attempts I ran Tool32, but then it had no effect)
I ended up using Easy BMW Tools from here https://mega.nz/#F!YE82wDha!MTgUZTlrpxN ... g!5McjmQpK - lots of other good stuff there
I hope this helps, I'll try to update the doc asap, good luck
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
Z4Sparky
Post by Z4Sparky » Sun Mar 24, 2019 8:57 pm
Cheers man....that's really helpful.
Just a quick question, possible for Dave - in the last step of the coding (before resetting the steering angle sensor) where the big list of modules are coded (to tell the car the retrofit is there), what is actually getting coded to these modules?
Is it information taken from the VO that gets written to the other modules?
It all makes sense to me up to that point, but this step I just can't figure out what is being coded.
Mark
tintoverano
Post by tintoverano » Mon Mar 25, 2019 8:37 am
it may be that specific VO codes trigger specific functions in different ECUs and that's the reason, so a new VO code is propagated all the way down
mSport 23i
Z4Sparky
Post by Z4Sparky » Mon Mar 25, 2019 9:05 am
tintoverano wrote: Mon Mar 25, 2019 8:37 am it may be that specific VO codes trigger specific functions in different ECUs and that's the reason, so a new VO code is propagated all the way down
That does make sense....cheers!
Z4Sparky
Post by Z4Sparky » Mon Mar 25, 2019 7:06 pm
Just a quick question regarding the stalks.
Just bought some from an E90 with part no. : 61319123041
I checked realoem and that says this is for a car with MFSW, rain sensor and Cruise control, so seems exactly what I need and a snip at £45, but just not sure if it will work as its a different part no. to the version for the Z4 (61319123049).
Anyone got any thoughts if this will be okay? Or should I just buy the correct part no.?
clarker63
Post by clarker63 » Mon Mar 25, 2019 7:19 pm
Z4Sparky wrote: Mon Mar 25, 2019 7:06 pm Just a quick question regarding the stalks.
probably. there's enough commonality between those two vehicle lists for those parts, but sometimes its not obvious why there's a difference.. Give it a go. Its not too hard to take it out if thats the case.
35is, sadly gone, but not forgotten.
Z4Sparky
Post by Z4Sparky » Mon Mar 25, 2019 7:25 pm
clarker63 wrote: Mon Mar 25, 2019 7:19 pm
Cheers Clarker....just been reading your posts over on BabyBMW about it....very useful!
Mark
clarker63
Post by clarker63 » Mon Mar 25, 2019 7:37 pm
Z4Sparky wrote: Mon Mar 25, 2019 7:25 pm
Mark
annubiszed has a good thread too on here. nice to have a video as well :thumbsup:
cjp1800
Post by cjp1800 » Mon Mar 25, 2019 9:15 pm
Using the excellent guide on page one, I've successfully installed CC on my 2014 2.0 E89. It seems to work perfectly, apart from the minor detail of the error message "cruise control failure". :D
Would you have any idea where I have gone wrong, clearing the fault is only a temporary solution.
Chris
2014 BMW Z4 sDrive20i
AnubisZed
Post by AnubisZed » Tue Mar 26, 2019 3:55 pm
Right guys sorry for no comments back but for some reason I'm no longer receiving notifications for this thread, don't know why as I was before.
Right, I'm going to go through them as much as I can.
Firstly though the guide is made up of other information I found along the way, not all entirely my work.
tintoverano, you've done well :thumbsup: as you've spotted FRM isn't in the e89 list it's NFRM as you've spotted.
I'll be looking at another update on it again to rectify the problems you've noticed.
Z4Sparky, yes that stalk assembly should be fine as long as you have auto lights and auto wipers then it'll do the job.
Dave
2011, 23i, Grey with Red leather. 8)
tintoverano
Post by tintoverano » Tue Mar 26, 2019 4:52 pm
sounds great :thumbsup:
also, please put a note to the beginning of the first doc: don't close the boot after disconnecting the battery :headbang: :D
mSport 23i
clarker63
Post by clarker63 » Tue Mar 26, 2019 5:28 pm
cjp1800 wrote: Mon Mar 25, 2019 9:15 pm Using the excellent guide on page one, I've successfully installed CC on my 2014 2.0 E89. It seems to work perfectly, apart from the minor detail of the error message "cruise control failure". :D
Chris
not seen this message when I installed it. If its all "working" but producing an occasional error (does this happen every time you run it after clearing it?), its something a little more subtle than an installation error I would assume.
AnubisZed
Post by AnubisZed » Tue Mar 26, 2019 8:57 pm
clarker63 wrote: Tue Mar 26, 2019 5:28 pm
Chris
No can't say I've seen this before either.
As long as the physical connections are correct and the VO and the FSW_PSW.TRC are correctly written and you've run Tool32 correctly then it should be fine. the only other thing could be a faulty stalk, but I doubt that.
Dave
cjp1800
Post by cjp1800 » Tue Mar 26, 2019 9:10 pm
Ok, thanks for the replies, I'll double check.
Chris
