Service cost & Intervals
"M" Specific discussion
dgm
Post by dgm » Mon Aug 28, 2017 5:53 pm
nickw6666 wrote: Fri Aug 25, 2017 6:11 pm
Technically, the Inspection II is not time based but distance based. The service schedule according to SII runs Oil Service - Inspection 1 - Oil Service -Inspection 2. The intervals are measured by the SII but usually work out at 15K average between services.
I disagree with this, the service is not mileage based but purely on the amount of fuel consumed. If you drive the car the way it's intended the amount of miles between required services will drop drastically. I doubt any Z4M or E46 M3 has ever achieved anywhere near 15000 miles between services, you would need to drive it incredibly slowly and on constant long distances to even get remotely near it. The service indicator will show 15,500 miles after being reset, its purely notional.
06 Z4MC, Sapphire black, Aero sideskirts, BMW strutbrace, CSL's, Remus back boxes, Intravee and Alpine DAB
dgm
Post by dgm » Mon Aug 28, 2017 6:01 pm
From memory I think the figure is 2275 litres of fuel between services or 2 years, whatever comes first. The car counts the fuel used and not the mileage done.
mmm-five
Post by mmm-five » Mon Aug 28, 2017 6:37 pm
dgm wrote: Mon Aug 28, 2017 5:53 pmI disagree with this, the service is not mileage based but purely on the amount of fuel consumed. If you drive the car the way it's intended the amount of miles between required services will drop drastically. I doubt any Z4M or E46 M3 has ever achieved anywhere near 15000 miles between services, you would need to drive it incredibly slowly and on constant long distances to even get remotely near it. The service indicator will show 15,500 miles after being reset, its purely notional.
Max I ever got between services (according to the OBC) was 14,500 miles.
Most of those miles were my regular commuting every (400+ miles of M62/M6/M40/M25)...but there would have been the odd Wales/Lakes/Peaks hoon, National meet, Ring trip, and track day in there.
Although it always had interim oil services too...without resetting the OBC.
If we work it out on my average mileage of 27mpg, then 500 gallons (2275 litres) 13,500 miles.
Cars used for short trips, town driving, track days, or 'weekend hoons' only will get considerably less between services - as they'll either be on cold-cycle fuelling (i.e. rich) stop-start driving, or pedal-to-the-metal through Wales :P
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
dgm
Post by dgm » Mon Aug 28, 2017 6:49 pm
I salute you, 14500 between services is good going. Best I ever achieved MPG wise over a sustained distance was about 26mpg on a couple of 3000+ mile journeys to France. That was just driving the car as fast as the conditions would safely allow most of the time.
Z4MPO
Post by Z4MPO » Tue Aug 29, 2017 10:14 am
thanks guys, this is really useful and will opt for oil change and brake fluid. I agree that every 2 years is important. My car gets very light use as its pretty much a garage queen now, so when I take her out, its always on a nice day and a country road!
2006 Z4M Roadster
2004 330ci M Sport Conv
2002 325i Sport
2000 520i SE
1999 Rover 214iSE!
nickw6666
Post by nickw6666 » Tue Aug 29, 2017 9:42 pm
I agree with you that it isn't mileage based. I just said that the average they quote for the car is 15,000, but they measure more than one attribute to determine actual service interval. So it's not just fuel used, it includes number of starts and other parameters such as lots of short or long journeys.
My previous daily driver was a 330Ci, which uses the same system of parameters on the SSI as the Z4M, and this used to deliver between 15-16k between services consistently. I don see the Z4M being different if driven in the same way. My journeys were a mix of long and short, BT my commute was 30 miles round trip.
I've not done enough miles between services to test the 15,000 miles average, but based on mileage in relation to the moles behave driven, I believe I would be getting around that figure between services if I drove enough miles.
2007 Imola Red Z4M coupe. Owned since January 2008.
Previous: 2009 Guards Red Porsche Cayman S 987.2 Gen II
Previous: 2015 F82 M4 coupe - Mineral White, DCT
Previous: 2007 Meteor Grey 997.1 Porsche 911 Carrera S
TomK
Post by TomK » Tue Aug 29, 2017 10:19 pm
nickw6666 wrote: Tue Aug 29, 2017 9:42 pm
That's just not true. As has been said it is calculated on fuel used, just like it would have been on your e46. The mileage indicator is just an approximation of the what it thinks your fuel consumption will be over the period. It's quite easy to show this by doing a track day or high speed 'autobahn' run where you may be pulling single digit mpg for a while. Turn your engine off and on again and see that the mileage to the next service is considerably reduced compared to the amount of miles you've just completed.
Of course this system inherently takes into account if you did loads of stop start journeys or cold starts or long motorway journeys etc they all significantly affect mpg. What it most certainly doesn't do is log all of your journeys and work it out from that!
dgm
Post by dgm » Tue Aug 29, 2017 10:24 pm
Nick, I don't know where you're information comes from but I'll say this. I've been driving S54 engined cars for the last 13 years and have spent far too much time for my own good reading about them. I have never seen any reference to other parameters being used to determine the service interval other than litres of fuel used or a two year time period. I also have never seen any literature that states that BMW expect a 15000 mile average between services. If you have evidence to the contrary then please post it up and I will have learned something entirely new about S54 ownership. My firm bet is that the only parameter used to determine service intervals outwith the two year maximum is litres of fuel used. Google it and you will find many references to it..
mad4slalom
Post by mad4slalom » Sun Sep 03, 2017 6:53 pm
Hi, the modern version of a service is an inspection, basically this means they look at it and say "it 's not broken yet !" It is very hard to find a garage that does a service that includes good old fashioned preventive maintenance. Just had a 25k first service on a 1 year old renault master van ,( I had already done an oil and filter change at 12k as i think 25 is way too long. ) i expected them to strip and clean the brakes, gease the caliper pins, check the wheel bearings, clean , adjust and grease the handbrake mechanism, change the gearbox oil and grease the steering and suspension . They didnt even take the rear wheels off. So now that van according to service schedhule will go another year and another 25k without any maintenance at all. Basically , i have paid the cost of the service for an oil change ! They didnt even change the air filter or fuel filter, so now i have to pay someone else to do all those things again for my own peace of mind as i go to london every three weeks. Bmw inspecs one and two are actually not very invasive, and we are paying mega money for very little, under the guise of it beibg an M car and needing specialist attention. Read the schedule and see how much of it is "checking " of items and not changing . I go to a good independent but specify what i want and expect done and also fettle things myself as no garage has the time or inclination to do the little things that we can do at home. I pity owners who are not mechanical or engine litterate who are totally in the hands of garages and dealers. :x
carl
Post by carl » Sun Sep 03, 2017 9:31 pm
Makes you wonder, doesn't it? The last few (non-M) BMWs I've had don't have changing the gearbox oil on the schedule at all. Ever.
nickw6666
Post by nickw6666 » Tue Sep 05, 2017 9:42 pm
dgm wrote: Tue Aug 29, 2017 10:24 pm
dgm, I got my information from BMW Main Dealer service Department x2. So they are giving me wrong information if it is just based on fuel consumed.
I've googled it and it seems that older BMW engines indeed looked at more parameters than purely fuel consumed, so maybe it was simplified for later cars as the fuel consumed took into account shorter and longer journeys by reflecting this in the fuel consumption.
I've had BMW cars with with S54 for 10 years, M54 for 7 years, N54 for 4 years, M52B20 for 2 years, M52B25 for 2 years, and M52B28 for 1 year covering roughly 400,000 miles in total. In my experience, the M54 and N54 engines ran to 15,000 miles between services, but then I did quite a lot of motorway miles, and with my N54, I now change the oil every 7500 or 1 year.
I didn't say 15,000 miles was stated by BMW, how could it be when it's a variable interval, but I have seen some of their service material stating that the variable service interval often works out to around 15,000 miles on average.
With S54 as I'm sure you know, the service interval defaults to 15,000 after an oil/inspection service and counts down from there. So BMW obviously has that figure in mind as an average otherwise they would not use that number. What I've noticed is that my mileage usage is remarkably close to the countdown of the service interval within the service period.
With my S54 though, I've not reached a 15,000 mile service interval though between oil changes and never will as I change at 7500 miles or 2 years etc.
dgm
Post by dgm » Wed Sep 06, 2017 10:02 am
Even when they were new I found that BMW main dealers weren't the most knowledgeable about these cars. Over a decade on and with their huge turnover in staff, I find it difficult to get anyone in the dealerships who understands the service requirements of the S54. The valve clearances are the most obvious example of that, just listen to the engine and if it sounds OK then just leave it alone seems to be the mantra.
It's been a while since I did enough miles in my Z4 to trigger a service prior to the two year maximum period but when I did I was a long way off from 15,000 miles. I don't have access to my service book presently to be precise about the distances. It could be the way I drive but that's my experience. As I say the service reset showing 15,500 miles until the next service is notional only.
Fishy Dave
Post by Fishy Dave » Wed Sep 06, 2017 11:14 am
mad4slalom wrote: Sun Sep 03, 2017 6:53 pm Hi, the modern version of a service is an inspection, basically this means they look at it and say "it 's not broken yet !" It is very hard to find a garage that does a service that includes good old fashioned preventive maintenance. Just had a 25k first service on a 1 year old renault master van ,( I had already done an oil and filter change at 12k as i think 25 is way too long. ) i expected them to strip and clean the brakes, gease the caliper pins, check the wheel bearings, clean , adjust and grease the handbrake mechanism, change the gearbox oil and grease the steering and suspension . They didnt even take the rear wheels off. So now that van according to service schedhule will go another year and another 25k without any maintenance at all. Basically , i have paid the cost of the service for an oil change ! They didnt even change the air filter or fuel filter, so now i have to pay someone else to do all those things again for my own peace of mind as i go to london every three weeks. Bmw inspecs one and two are actually not very invasive, and we are paying mega money for very little, under the guise of it beibg an M car and needing specialist attention. Read the schedule and see how much of it is "checking " of items and not changing . I go to a good independent but specify what i want and expect done and also fettle things myself as no garage has the time or inclination to do the little things that we can do at home. I pity owners who are not mechanical or engine litterate who are totally in the hands of garages and dealers. :x
My view exactly :thumbsup:
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
srhutch
Moderator
Moderator
Post by srhutch » Wed Sep 06, 2017 1:55 pm
I think we really are splitting hairs here. The time to service is reporting in miles on the odometer. Yes this might be directly linked to the amount of fuel used, but if you car said service required in 2,500 litres you'd be heading straight for your calculator to work out what it meant mileage wise.
I've always quoted around 13,000 miles between services and will continue to do so.
dgm
Post by dgm » Wed Sep 06, 2017 3:13 pm
Your car has always been low mileage use though has it not? Have you ever come close to doing 13,000 miles before the two years has crept up on you? I don't think it's splitting hairs really, the service criteria is either definitively litres of fuel used or fuel used plus other parameters which the car measures. I think there are no other parameters other than fuel used and would genuinely like to clarify for myself and others if that's the case. That's why I enquired of Nick where he had obtained his information.
