Rough cold start with 35is
Ozie
Post by Ozie » Fri Nov 03, 2017 4:55 pm
Z4M-2006 wrote: Wed Nov 01, 2017 10:09 am Yea,
Classic HPFP problem
Thanks. Got also new symptom... :roll:
If I try to accelerate harder car starts to "shake" bit like hitting the rev limiter. No warning lights and no fault codes. Earlier got few codes from same aymptom: Instrument Cluster shutdown A559 and Motor Control - ECU 55 "sorry, unknown DTC fault" 00DE51. I mean is this also HPFP problems or something else?
Z4M-2006
Post by Z4M-2006 » Fri Nov 03, 2017 5:11 pm
The HPFP sounds like its faulting and dropping pressure,under demand the fuel pressure is dropped to the injectors and misfires start to happen.
tomscott
Post by tomscott » Fri Nov 03, 2017 5:32 pm
Another with injector issues :cry:
Z4M-2006
Post by Z4M-2006 » Fri Nov 03, 2017 6:42 pm
All "N" derived engines have injector problems...
Dont have to have double windmills on em
Ozie
Post by Ozie » Wed Nov 22, 2017 6:55 pm
HPFP was replaced yesterday. Ignition is now much faster and better. Starts after first crank. No error codes while accelerate. Total cost was about 950 €/ $1120 / £850.
Still noticed vibration when tried to accelerate uphill with 7th gear from 40 mph to 60 mph. More in here viewtopic.php?f=45&t=89585
Z4M-2006
Post by Z4M-2006 » Wed Nov 22, 2017 7:15 pm
Is it bringing EML on ?
Coil packs or vanos actuators would be my next thing..
Smartbear
Post by Smartbear » Wed Nov 22, 2017 7:20 pm
Ozie wrote: Wed Nov 22, 2017 6:55 pm HPFP was replaced yesterday. Ignition is now much faster and better. Starts after first crank. No error codes while accelerate. Total cost was about 950 €/ $1120 / £850.
That sounds a very low speed to be in 7th & accelerating uphill, maybe the vibration is just the engine labouring at such low rpm?
e85 3.0si sold
Ozie
Post by Ozie » Wed Nov 22, 2017 9:50 pm
Z4M-2006 wrote: Wed Nov 22, 2017 7:15 pm Is it bringing EML on ?
Nope. No codes or lights.
Ozie
Post by Ozie » Wed Nov 22, 2017 9:57 pm
Smartbear wrote: Wed Nov 22, 2017 7:20 pm
It's way more rough. You'll get that wtf feeling when it hits. Bit like hitting rev limiter or wheel spin dsc engadged (no dsc lights) by suprise.
