z4m bumper
- ranski
z4m bumper
If I recall you have to do a bit of cutting on the M undertray edges to fit the non M, nothing too drastic
Z4 3.0 / Mods done... too many to mention
- Panta Rhei
z4m bumper
Sorry but I don't understand. If I have M bumper, M central undertray and side undertrays from the M aswell, what possibly cannot fit there that cutting is necessary?
- maxman
z4m bumper
If you fit the m undertray only,you have to do a bit of cutting on the std side trays to make the m undertray fit.That is the way I fitted mine and I have had no problems.Hope this clears it up.
z4m bumper
A couple of questions if anyone can help, if i have a M undertray without the M side undertrays will i still need to cut the M undertray, if so if i have the M undertray and the M side undertrays will that fit without cutting.
And the last question is do you really need the M side undertrays will it fit fine without them
- kis
z4m bumper
It says a few posts above. If you have M undertray (you don't cut this) and you can use original side trays but they will need cutting.gideon87 wrote: ↑Fri Nov 03, 2017 3:36 pm A couple of questions if anyone can help, if i have a M undertray without the M side undertrays will i still need to cut the M undertray, if so if i have the M undertray and the M side undertrays will that fit without cutting.
Not sure if you use M sides. I assume that no cutting would be necessary.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- JINGLE
z4m bumper
As above, M bumper and M undertray are left alone, if using M lower corners they are also left alone. If you have standard lower corners like most who do the conversion do (me included) when you offer up the bumper you will see a small area where the fangs foul the lower corners, and you just have to cut a small section out of the plastic and then it all sits fine. It’s honestly not hard and you will see exactly what we mean once it is offered up
Certainly nothing to worry yourself about.
Shameless //M front end conversion snap
- 47432C2E-E2B6-4AB6-AA43-7B24C6E67AAC.jpeg (505.58 KiB) Viewed 705 times
- JINGLE
z4m bumper
Not the greatest of photos, but you can see where I have trimmed the plastic in the red circles.
Hope this helps
Hope this helps
- 924FB01C-F8A4-4F25-B680-568BD650F8A8.jpeg (599.76 KiB) Viewed 705 times
- Beedub
z4m bumper
OP don't bother, go for the aero setup, i think its less common and much cooler!
z4m bumper
I bridged the gap by screwing in a bit of plastic
Cost about £5. - the undertray is so expensive
- Panta Rhei
z4m bumper
Guys, does Z4 M bumper require the piece below? I thought you attach undertray to bumper itself and here in my car there is additional connector between bumper and undertray.
car: 3.0si automatic transmission
