jimbo1958 - Intravee Install
- bribrolly
Re: jimbo1958 - Intravee Install
sorry to open an old topic but did you ever sort the ibus noise? im experiencing the same problem. again i would highly recommend the intravee even with the noise but would like to know if anyone has found a solution?
How have you fitted the intravee and the kca420i? When I first fitted mine, I had the cable between the two coiled up next to a silver unit, which I assume to be an amplifier. Listening to the ipod I was getting some interferance which I didn't have when it was fitted to my M3. Having moved this cable, it seems to have got rid of the interferance.
Still having major problems with the intravee after updating the software, however the intravee support is brilliant so far.
- pvr
I have issues as well, just remember the most important button: The satnav one.
Press that for 3 seconds or so, and you get back to the "now playing" menu where you can do everything again, great for when you are stuck - like I am often
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- playalistic
Which one is that then?pvr wrote:I have issues as well, just remember the most important button: The satnav one.
- pvr
The right knob (not you ).
Press that from any menu, or anywhere, and you will get the "now playing" list. The same knob you use to select menus etc.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- playalistic
Ah, cheers.
- jimbo1958
Never sorted it out. Thought it was gonna be an issue but it's only apparent when playing at louder volumes than I'd normally use during quiet songs.bribrolly wrote:sorry to open an old topic but did you ever sort the ibus noise? im experiencing the same problem. again i would highly recommend the intravee even with the noise but would like to know if anyone has found a solution?
Very rarely hear the hiss now......but I know it's there.
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Jaguar F Type V6s Roadster
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
