Rod bearings at 51k
Rod bearings at 51k
I had mine done last year. 107k miles. Excellent history. 6 worn to the copper. I can relax now lol
2007 Z4m coupe, sapphire black/black
Rod bearings at 51k
Just had my Rob bearings changed by Darragh at Everything M3s and got lucky too as three top shells were worn down to copper, mileage 105k and impeccable service history and enthusiast owned before me.
Also changed the oil pump at the same time since BMW revised the oil pump design many times, before settling on the last iteration in 2007.
Been advised to stay below 4k revs for 1,200 miles and will be going back for a running in service as advised by Darragh.
2008 Z4MR Ruby Black, Sepang Hell, Carbon Weave
2006 Z4 3.0si Montego Blue, Imola/Black individual
NCS/ISTA diagnostics & coding in Midlands - pm me
Rod bearings at 51k
I was told 800 miles and 4.5k revs, no harsh accelerating and don’t let the engine labour. But I’ve known people to have their shells done and put it straight on track with no issues. I’ll be dumping my oil again when it’s hit 1,000 miles. Just because I’m now Guna run millers nano drive oilWassup wrote: ↑Mon Aug 07, 2023 7:47 pm Just had my Rob bearings changed by Darragh at Everything M3s and got lucky too as three top shells were worn down to copper, mileage 105k and impeccable service history and enthusiast owned before me.
- BMWZ4MC
Rod bearings at 51k
I changed mine at 50k miles after c. 25k miles driven by the first owner and 25k miles of spirited driving and very frequent, hard track use by me. They were all in good condition.luckyfinners wrote: ↑Fri Jul 07, 2023 6:36 amI don't think I've ever seen a set of bearings that have been changed for the 2nd time, with the car being warmed up properly since the replacement (and enough mileage to wear) to see if the wear rate decreases.
Would certainly be interesting.
What run in period did you give the new bearings before giving it full throttle?
I’m now at 90k miles and I’m planning to change them again at 100k. In the period between 50k and 75k miles, the car saw as many track miles as it did road miles, so it will give a measure of how track use affects wear rates.
S2000 GT - gone
Rod bearings at 51k
Potentially getting at Z4MR, on 60,000 miles. Roughly what is a bmw specialist charging for a replacement?
Rod bearings at 51k
A running-in service for hydrodynamic journal bearings doesn't seem logical to me at all. I would understand the need for one after a full engine rebuild due to the new piston rings 'bedding' in to the fresh cylinder hone. Unnecessary expense if you ask me.
E85 M, Aero Skirts and Hardtop
Schrick 288/280 Cams and Rockers
Karbonius Race Airbox
BMW Motorsport 4.1 FD
Supersprint Full System inc 100 Cell Cats
163M CSL Rims
Bilstein/Eibach B12
Recaro Sportster CS
Diagnostic scanning and coding in Essex
163M CSL Rims
Bilstein/Eibach B12
Recaro Sportster CS
Onlinelucasxdiniz
Rod bearings at 51k
I'm a Powertrain Design engineer, so I'd like to think I have a good understanding of engines and when purely considering the function of the part, I agree with you. However, I did ask the engine builders at work if I should do an oil change because of assembly lube which can linger around and clog filters if someone abuses it (conjecture). They reckoned since it's just the rod bearings, there wouldn't be enough around to a) affect the oil (when dissolving within the oil) and b) clogging up the filter (not something they've ever seen happen in engines they've built). They suggested I could change the oil filter since it's so accessible just for peace of mind.
Z4MC: Interlagos Blue | Individual Champagne | BC Racing RS Coilovers | Powerflex Arms | 4.1 FD
Rod bearings at 51k
I change my oil filter every 2 to 3 thousand miles between oil changes, for around £10 to £15 it is cheap insurance for the engine.lucasxdiniz wrote: ↑Fri Aug 11, 2023 9:10 pm They suggested I could change the oil filter since it's so accessible just for peace of mind.
Rod bearings at 51k
There’s no need to run the engine in post bearing change.
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Rod bearings at 51k
129k miles bearings same condition as OP
My tech said that they will look the same right after 20k no matter the miles on the car.
- Mr Tidy
Rod bearings at 51k
They probably wouldn't look pristine after just 20K, but the third from bottom in your photo looks much worse than any of mine did after 78K miles.
But at least new ones give you some peace of mind.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Rod bearings at 51k
No, its just light situation, 3rd one looks exactly same as on OP picture
- Mr Tidy
Rod bearings at 51k
Fair enough - mine looked much like that too!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Rod bearings at 51k
Just to add to the data, I’ve just had mine done at 75k.
I’ve owned the car for 10 years and from 30k to 75k and I’ve been ultra diligent in keeping the revs and load low during warm up. Looking at the pics, I could probably have got a fair few more miles out of them but as we all know, the cost of misjudging this is high.
On another note, Redish have been fantastic-my sump had a repair done a few year back thanks to the threads being stripped by an unknown monkey. Unfortunately this has not been done perfectly so has meant a new sump has had to be ordered. Not a cheap or easily found part but communication and their willingness to help has been second to none.
If anyone for any reason someone wants a Z4m sump with a less than perfect repair then let me know. I’ll hopefully be picking the car up in the next day or two so be quick or I’ll just leave it for scrap. They’ve said it might be possible to use a timesert but because of the previous repair they weren’t convinced it would hold.
RUBYIMOLACARBON
