Post
by un1eash » Thu Jun 17, 2010 11:22 am
I dont know how you will get this to work with the Carver as the Parrot basically has its own built in amp which it uses when you make calls and play music through it. To connect it to a standard radio it uses an ISO Y split loom which allows the parrot to switch between the radio as a source and itself.
Because the carver system has its own amp in the rear and all the speakers connect to this its more difficult if not impossible to integrate a parrot system.
Ive just installed this kit in my mates Range Rover Vogue which has a system very similar to the carver and the only way to do it was add an extra speaker to the centre for the parrot system to use but then its only good for phone calls with one speaker.
