BMW headunits which support MP3
- Taz
Re: BMW headunits which support MP3
should my MP3 player read dvds or will it only read cds
i've tried burning a dvd but the players just gives error message (its a 2009 bmw business cd player)
- pvr
Can not read DVDs.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Andy
& no i dont believe a new changer works on an old head unit for mp3s.
Imola Z4MR #0026 6 yrs, & 66k so far..
i have ended up puting in a harmon kardon mp3 adapter thing. got a display and everything. 16gb ipod which charges as i drive, its great.
- Taz
not what i wanted to hear but thanks anywaypvr wrote:Can not read DVDs.
- ryukin
Just out of interest, how much was the satnav system and was it easy to fit? Also (may be a dumb question) does it have a tv function too?pvr wrote:Vents were about £25 I think ...
This was my previous Toledo blue 2004 (march) car after I installed the OEM satnav system, where I removed the grey radio with black (as well as the vents).
- srhutch
- Moderator
PVR, DHK and myselff to name but three have done the SatNav retro fit, time to do another search .
Cost is £500-£600 and is failry easy apart from cutting the hole in the dash which is nerve racking. It takes about a day to fit as well.
I will help you with this one
http://www.z4-forum.com/forum/viewtopic ... tch#p89945
- TH3R4POR
http://www.z4-forum.com/forum/viewtopic.php?f=29&t=6067ryukin wrote:was it easy to fit?
you're great for my post count
edit: damnit, beaten by seconds
- ryukin
i found that thread just after i posted! but thanks anyway. I'd love to retrofit this. Each time I fit something new on my car I get a great sense of achievement! I would be cacking myself though while cutting a hole in my dash. I'd almost certainly screw it up. Does anyone know if it has the tv function or is it just satnav? (sorry, i know this is slightly off topic!)
- srhutch
- Moderator
You need an extra widget for TV, readily available but at a cost.
If you go ahaed get yourself a dremel with the flexible attachment, much easier than any other method, and just take you time. Cover the dash with towels so if the dremel slips hopefully the towels will protect. And just remember you can cut the hole bigger but not smaller so take your time.
- pvr
I covered the dash edge with thick double layer tape as well, in case of slipping ...
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- srhutch
- Moderator
but it took you 5 days to cut the holepvr wrote:I covered the dash edge with thick double layer tape as well, in case of slipping ...
- pvr
At 1 hour each evening, yes. Got sick to death sniffing the burning plastic with your head stuck against the windscreen
It was so much easier the second time around with the M. Just a pencil mark against the option on the spec sheet
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Is that all HIFI Professionnal DSP models are compatible with MP3?
Or this is only for the 2005 models?
