I do! But I've resolved that. I keep a photo of the garage wall in the car, so I can use thatPbondar wrote: ↑Mon Dec 09, 2019 10:45 amI assume you never park anywhere else that has a wall?enuff_zed wrote: ↑Sat Dec 07, 2019 8:34 pmI have the same issue with my garage. But no PDC!!!!Busterboo wrote: ↑Sat Dec 07, 2019 12:52 pm
You forget that the PDC viewer can be used forwards, too. I use it that way every day, because I park under the house in a space between a wall and a brick pillar covered in ivy that's only a few inches wider than the car. Reversing out is easy - I use the mirrors - but driving the long-bonneted E89 in is safer with some help.
So, the first time, I drove in to what I thought was right, stopped, got out, checked the gap and pushed the car forward to the right spot.
Then I got back in, made a visual note of where I was in relation to wall bricks etc.
Been fine since then. Simples!
Rotate the pdc graphi
- enuff_zed
Purfeckenuff_zed wrote: ↑Mon Dec 09, 2019 11:12 amI do! But I've resolved that. I keep a photo of the garage wall in the car, so I can use thatPbondar wrote: ↑Mon Dec 09, 2019 10:45 amI assume you never park anywhere else that has a wall?enuff_zed wrote: ↑Sat Dec 07, 2019 8:34 pm
- RustyZ4
I get the pdc viewer, use mine all the time,, I just wondered why you would want to rotate itBusterboo wrote: ↑Sat Dec 07, 2019 12:52 pmYou forget that the PDC viewer can be used forwards, too. I use it that way every day, because I park under the house in a space between a wall and a brick pillar covered in ivy that's only a few inches wider than the car. Reversing out is easy - I use the mirrors - but driving the long-bonneted E89 in is safer with some help.
Z4 E85 3.0, gone but now with son
It's not me who wants to rotate it. I'm happy with it the way it is.
Vidi, vici, veni
- Tarzan
For those who want to make the change with NCSExpert
PDC_DIRECTION
horizontal
Change to vertikal
PDC_DIRECTION
horizontal
Change to vertikal
- enzed4
I gave it a go (coded it in Carly) after reading this thread. To be honest it doesn't make much difference to me, more of a novelty to have a different display than anything really practical. The only annoying thing is that the picture of the car doesn't seem to display on the screen for up to 15-30 seconds after putting it in reverse (the 'radar' display works instantly but it looks weird without a car image on the screen, just the colours). There was always a slight delay in the landscape mode but nowhere as long as the one with the portrait (F type) display.
Think I'll code it back to normal next time I'm doing some coding.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- buzyg
I simply switch the lights on and use the reflected light to judge how close to the wall I am. Same principle as PDC, for us poor folk.
Tennis ball on a string against the windscreen....enuff_zed wrote: ↑Sat Dec 07, 2019 8:34 pmI have the same issue with my garage. But no PDC!!!!Busterboo wrote: ↑Sat Dec 07, 2019 12:52 pmYou forget that the PDC viewer can be used forwards, too. I use it that way every day, because I park under the house in a space between a wall and a brick pillar covered in ivy that's only a few inches wider than the car. Reversing out is easy - I use the mirrors - but driving the long-bonneted E89 in is safer with some help.
