How-To - e89 Cruise Control Retro-fit
- Barneybee
Dave, Thanks for the update.
Never drive faster than your angels can fly
2016 E89 SDrive 2.0i MSport Auto Valencia Orange
New link to the revised Part 2 (the coding How-To) has been added to post 1.
The How-To has had a few minor revisions, the content is basically the same but with a couple of typos corrected
Dave
2011, 23i, Grey with Red leather.
- tintoverano
cheers
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
If anyone is interested in Cruise Control but don't fancy messing with the coding then I'm happy to undertake this for you.
I'm based in Grantham, Lincolnshire, PM me and we can talk about your requirements
I'm also looking at producing an instructional video on this retro-fit as well, once the weather warms up a bit
Dave
- tintoverano
hi Dave, did you manage to replace the doc with the improved one by any chance?
doing this tomorrow
thanks
mSport 23i
- tintoverano
yes, thankstintoverano wrote: ↑Fri Mar 22, 2019 9:27 pmhi Dave, did you manage to replace the doc with the improved one by any chance?
doing this tomorrow
thanks
mSport 23i
New, replaced doc at the link on post 1tintoverano wrote: ↑Fri Mar 22, 2019 9:28 pmyes, thankstintoverano wrote: ↑Fri Mar 22, 2019 9:27 pmhi Dave, did you manage to replace the doc with the improved one by any chance?
doing this tomorrow
thanks
Dave
- tintoverano
hi, I made a stupid thing
let the boot go down just enough to click after removing the negativ cable from the battery
and I'm not able to open it now
any advice?
thanks
any advice?
thanks
mSport 23i
- tintoverano
I was lucky, let the positive on and by attaching a charger I could send voltage to the trunk motor, key opened it
mSport 23i
- tintoverano
Dave, I run the recalibration using Tool32, job ended with okay
though I still have FTM and DTC warning
what do you suggest?
thanks
thanks
mSport 23i
Have you read this post:tintoverano wrote: ↑Sat Mar 23, 2019 4:19 pm Dave, I run the recalibration using Tool32, job ended with okay
thanks
viewtopic.php?f=23&t=111701
There might be a few pointers there to make sure you have everything correct.
2010 E89 sDrive 2.3i Alpine White
- tintoverano
thanks, I'll check
went for a short ride to see whether the control works, it doesn't
so the coding didn't go down 100% and I have the two fault codes
coding: I used the software I got with the cable and from setting Vehicle Order I had different commands available, though I did select FRM etc., so this could a reason where it went south
I'll install now the sw package you have in the guide and give it another try
at least I didn't brick the car
mSport 23i
- tintoverano
so, I started using the package from the guide, repeating all the step from the beginning
1. at step 18 I already had wert_02 for TEMPOMAT_SETZ_ANZ_DAUER, this got written OK into FSW_PSW.TRC
2. anyhow I coded this again and arrived to this screen NCSExper: 3. at step 21 I didn't have this MANUAL profile or any of the others what is shown in the guide on this picture:
since now I'm using the software from the guide, I expected this profile available
when I did this the first time, I missed that I tried to achieve coding using the commands available and perhaps this is the cause of the problem
I guess these profiles come with the install, but I don't have it after the install, strange
Dave, could you please share the PFL directory from your NCSExper install? (profile files are quite small)
thanks
thanks
mSport 23i
- tintoverano
more info, tried another install of Easy BMW Tools and the profile coming with it
whichever app or profile I used I ended up not getting FRM listed in the dialog box to write Vehicle Order there as well
(writing into CAS the famous $544 was OK, it appears just fine as already added)
why don't I get FRM listed for the 2nd VO job?
I got it here at Step 7, just like it is in the guide, but going from her to try coding the VO into FRM doesn't work
- Screenshot 2019-03-23 at 22.00.55.png (71.39 KiB) Viewed 2639 times
mSport 23i
- tintoverano
a quick update, all works now
I'll update.the guide with my findings and send it to you Dave
mSport 23i
