Sure thing buddy I think I better set an entire print bed full printing
Easy Lock Delete
- IAmOrion
Easy Lock Delete
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
- NickDE
Easy Lock Delete
Do the door lock covers work for the coupe ? Any photos ?
Darkness gone, go Darknes2, go Frozen, go Tronic
- thanatu55
Easy Lock Delete
Haha sorry mate!
At least this one is nice and cheap
- ben g
Easy Lock Delete
I definitely fancy some of these. Had something similar before, but it fell off somewhere and that was the end of that
- thanatu55
Easy Lock Delete
You won't have one of these ones fall out, or at least in my case it's on there pretty tight.
- thanatu55
Easy Lock Delete
[/quote]
Did you send me the door ones too? I think you might have done but I dove straight into this one I didn't check the rest! If so I'll get one of them done up and I'll post a photo over the weekend.
- ben g
Easy Lock Delete
Do they simply slot into the lock, or did you need to dab a bit of glue/silicone on them?
If they just slot in, then even better
- thanatu55
Easy Lock Delete
Just slot in, it didn't need anything else. It needs a fair bit of force to pull it back off again so I'd say it's pretty safe
- IAmOrion
Easy Lock Delete
Yes mate I did include a load of door lock ones for you too
Yes, by design the fit is bloody tight - you'll also have to take into account tolerances of 3D Printing. They fit perfectly in mine as that's what I measured on. By design it is a tight fit, but some may find they have to file the notch that goes into the lock down a fraction if it won't go in. When I tested on mine, it was stiff for sure, I had to push quite a bit to get it on first time round. After that I could get it one and off easy enough but it's still held tightly.
Also worth noting, I send 4 of each lock cover (Boot & Door) in each set to allow for breakage / paint experimentation / loss etc
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- IAmOrion
Easy Lock Delete
Assuming the size is the same then yes. I will get a picture of the plastic part fitted in door lock tomorrow for you. (Note: mine are unpainted straight off the print bed so won't look as matched as thanatu55's but it will show the fit )
If your locks are a different size, you could always discuss some measurements with me via PM and can get a set out to test
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- IAmOrion
Easy Lock Delete
If everyone is happy, I'm going to round it to £10 for a set printed in PLA. (PLA will be a random colour, since they will ideally need a layer of heavy primer to get rid of the print layer lines anyways, and then painted, colour of the material is irrelevant)
That covers the costs of printing them and includes p&p recorded.
There's 8 in total. 4 x Boot Lock Covers, 4 x Door Lock Covers
For What It's Worth, I'm not making profit, and don't intend to, I'm perfectly happy being able to offer something to the members of this forum
The boot lock is 36mm in diameter, the door lock is 20mm in diameter.
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
Easy Lock Delete
What a simple but great idea. Definitely worth a play with over the winter. PM incoming!
- IAmOrion
Easy Lock Delete
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- oldgitdave
Easy Lock Delete
Great idea . Mines debadged & I reckon these will really improve the look. PM sent IAmOrion
Zedless
