Just Installed new Viton orings and teflon seal rings, didn't need new bearings. The o-rings were so hard and flat that when I pulled it apart the pistons literally just fell out. Now the engine pulls hard with no lag.
- BumpyZ4
- 20240312_144516.jpg (250.37 KiB) Viewed 531 times
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
- Rsipad
- jock156
Retrofit Multifunction and Paddle shifters - only for shifters i need new steering wheel ring.
New lether cover on steering wheel, now i waiting for new side covers for steering wheel.
E53 4,4i
E70 4,8i
F10 - 530xD
E85 - 3.0i M54
E70 4,8i
F10 - 530xD
E85 - 3.0i M54
OnlineUsel
I recently added the paddleshifts, great addition to the car, better than I expected them to be
If you need a slip ring for the paddleshift I have one
Online1536Z4
Good job
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- Dubbedown
Is that chrome or just the lighting?
Follow latest mods on Imolarot_S54 M Coupe OEM+
Had both rear brakes binding for a while so done some investigating.
Both caliper seals shot and corrosion inside the boots.
New seals, pistons and slide pins fitted, all corrosion cleaned off and brakes bled.
Online
Good job there.D.Bryce wrote: ↑Sat Mar 23, 2024 8:03 pm Had both rear brakes binding for a while so done some investigating.
2003 Maldives Blue 3.0i auto
Online
Me too. Three litres of M54 torque + sport mode + paddleshift is actually quite fun
- x-driver
What instructions did you follow to take the VANOS apart and back together?
- BumpyZ4
I watched several different YouTube videos. One by the 50's kid and one by shoplifetv are pretty good. The only hard part is the limited space to get the VANOS in and out of the car. All the videos are on E46's which have a ton of room!x-driver wrote: ↑Sat Mar 23, 2024 11:57 pmWhat instructions did you follow to take the VANOS apart and back together?
KLR 650
KLR 650
- x-driver
Ty
E46 having more space than Z4? I'd guess it'd be the other way around
Is there any danger of getting the VANOS out of phase? Any special tools needed?
its chrome and this is a reason why i need something other, something like aluminuim color.
E53 4,4i
E70 4,8i
F10 - 530xD
E85 - 3.0i M54
E70 4,8i
F10 - 530xD
E85 - 3.0i M54
