Yes, updated brackets from RallyRoad.net and also new longer brake lines from them as well. I used new SS bleeder valves and new seals and silicon dust covers. The decals are heat resistant for calipers.
- 3gGT01
2007 Z4MC Interlagos Blue Metallic w/Light Sepang Bronze Nappa interior. 'Emma'
- 1536Z4
Photos of diffuser . Overcast weather so not the best lighting .
- 20240315_162006.jpg (165.13 KiB) Viewed 464 times
- 20240315_161913.jpg (393.21 KiB) Viewed 464 times
- 20240315_161845.jpg (137.9 KiB) Viewed 464 times
- 20240315_161759.jpg (254.62 KiB) Viewed 464 times
- 20240315_161740.jpg (97.36 KiB) Viewed 464 times
- 20240315_161728.jpg (127.92 KiB) Viewed 464 times
- 20240315_161715.jpg (126.13 KiB) Viewed 464 times
- 20240315_161640.jpg (176.6 KiB) Viewed 464 times
- 20240315_160501.jpg (152.63 KiB) Viewed 464 times
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
Just woken it up from winter and went for a quick pootle around to make sure everything is working as it should.
Now ready for our Sunday blast to the Cotswolds.
Now, I thought the road tax was going up at the end of this month, but no, the cnuts have already raised it to £395!!
God knows how much more it will rise next month!!
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- 3gGT01
Certainly turned out very well even with the complex curves involved!
- 1536Z4
Fitted a new Varta AGM battery as I thought the old Yuasa was leaking but looks fine. My mates that are still in the motor trade say “a better starter with Varta”
Now: Z4MC Titan Silver
Gone: E86 3.0Si Sport Titan Silver - M exhaust + bumper - Battery Relocated - Aero Front
E86 3.0Si Sport Silver Grey - Carbon Diffuser - Aero Kit - B/Box Mod - Storm MW V2
E85 2.5 Si Sport Titan Silver
- 1536Z4
Turned my coupe into a roadster and I`ve got the cut to prove it
Skewer to make hole for wire Wire cut whilst not paying attention
Please tell me you will be taking it for a drive like that
- 1536Z4
Definitely . Just for the fun of it as long as it isn`t raining
- Usel
Customised the paddles on my steering wheel. I wanted left pull down a gear and right pull up a gear so needed to change the paddles to suit this.
Lots of cutting and grinding of plastic but very happy with the final result:
- 1536Z4
Nice one .Wanted to do this when I had steering wheel off but couldn`t work out which wires to swap as my wiring was different to other cars that had done it where you just swap 2 wires over . I see you have changed the paddles as well . Did you take any photos of the install ? .
- Usel
Reading this thread will help you understand the birth of the project:1536Z4 wrote: ↑Sun Mar 17, 2024 11:56 amNice one .Wanted to do this when I had steering wheel off but couldn`t work out which wires to swap as my wiring was different to other cars that had done it where you just swap 2 wires over . I see you have changed the paddles as well . Did you take any photos of the install ? .
https://www.z4-forum.com/forum/viewtopi ... uto+paddle
To re-wire you can use a multimeter to find out what the paddle wires do. I think the wiring is different on a Z4 auto wheel, but with a photo I may be able to help.
There is so much customisation needed to make them fit. I started off with a normal standard wheel. The rear trims regardless of being paddleshift trims will need to be hacked so best to use normal trims. The back cover will also need to be hacked about.
Maybe I should start another thread but it won't be a guide unfortunately, more like a photo dump
The 1 series wheel is what I used for inspiration for the final look:
I like this.
What’s needed to do this?
Could you provide a list of parts and a little write up mate
2009 09 Carbon Black Cinnamon E86
Change new battery and try to get Optima Redtop fitted there. Works quite well, just 3d printed little shim part under battery bracket. Seems very nice and now car starting like new
E86 3.0si manual -07 Black-sapphire metallic
Really??? So you’ve replaced Push for down, Pull for up??? Why??? It’s the natural way of things, everyone else is wrong
