Anyone tried running a 9J front on an E89, specifically 18 x 9J ET 40, tire size marginally bigger than standard at 235/40/18.
Standard is 18 x 8j ET 29, will they fit suggests poke is about the same, but sit inboard by circa 15mm - not sure about strut clearance
Edit - ignore my rantings, looked at will they fit again and sit 23.7mm further in which (having looked at the car) suggests they’ll hit the strut.
18x9 et 40 235/40/18
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
OnlineB21
10mm spacer..
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
