Second battery?
Second battery?
I don't have a driveway so no way to charge my battery. So would it make sense to buy a second battery then swap them over every month so that one can be charged while the other is in the car? I don't use the car that often so don't want to be stuck with a flat battery.
As you can't open the boot once the battery is removed (for charging)I thought this might be a good solution. I do have the ski hatch though. But it sounds like this is a very awkward way to access the boot catch?
- Reamesy
Second battery?
If your new battery is good and the car has no issues then it should start no problem after a month
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
OnlineB21
Second battery?
The issue is that with ever swap you then need to re-register the battery..a bit off faff..
You could take the battery out and lock the car manually..
Then manually unlock the car..pop the bonnet..momentarily use the jump connector to give power to release the boot then re-attach battery etc..
Obviously fraught with f€£k up issues..
A very modified Atacama Yellow 35is
OnlineB21
Second battery?
Battery is good for 6 weeks but relies on it being fully charged to start with..
Second battery?
I've got the BimmerLink app so it's only a couple of minutes to re-register the battery each time. But if you keep doing this does it screw up the electronics?
Second battery?
Why not drop solar panel in window and run to battery.
All you need is something pushing electrons the right way around.
100w panel for £50.
100w panel for £50.
OnlineMr Tidy
Second battery?
Solar panel sounds like a good idea, but the easiest option might be to just use the car a bit more often and get more fun out of it!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Second battery?
Sounds like a good idea to me. Don't see an issue with multiple re-registering.JakeS76 wrote: ↑Sat Apr 27, 2024 1:58 pm I don't have a driveway so no way to charge my battery. So would it make sense to buy a second battery then swap them over every month so that one can be charged while the other is in the car? I don't use the car that often so don't want to be stuck with a flat battery.
If you buy a duplicate of the existing one, I am not convinced you would need to keep re-registering them, either.
Bit of a ball-ache keep lugging heavy batteries around, though.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- Big Andra
Second battery?
This is what I do with my van as it can sometimes sit for a couple of weeks without turning a wheel. It works a treat.
2009 E89 2.5 Alpine white.
2008 cayman 2.7 Arctic silver.
- DonDon
Second battery?
Just to reiterate - the battery is always charged via the red terminal in the engine bay (near the windscreen) and a ground connection, not via the boot.
2013 E89 28i auto
Second battery?
Solar panel solution works really well for motorbikes in my experience! In your shoes this is what I’d do. Or, lend the keys to a pal once a month! That’s what I used to do with the Vette.
2010 E89 35i — turbo boat hooligan - viewtopic.php?t=131886
2008 Ducati 1098S — two wheeled nightmare
Second battery?
I would avoid frequently disconnecting and reconnecting the battery option. In my experience the FRM module doesn't like it. and can be killed. It's not an inexpensive item. Just run a cable from the house to the car and bring it up under the car to the terminals in the bonnet. Make it a ground fault outlet and it will be safe.
OnlineB21
Second battery?
javis20 wrote: ↑Tue Apr 30, 2024 1:54 am I would avoid frequently disconnecting and reconnecting the battery option. In my experience the FRM module doesn't like it. and can be killed. It's not an inexpensive item. Just run a cable from the house to the car and bring it up under the car to the terminals in the bonnet. Make it a ground fault outlet and it will be safe.
Second battery?
Thanks everyone. My car isn't parked where I can run a cable to it, so either driving it more often or getting a solar trickle charger looks the best option.
Would an AA solar charger that plugs into the OBD2 socket work ok?
- Screenshot_2024-05-09-11-56-43-083_com.android.chrome.jpg (96.72 KiB) Viewed 168 times
- Screenshot_2024-05-09-11-56-23-933_com.android.chrome.jpg (47.88 KiB) Viewed 168 times
- Screenshot_2024-05-09-11-56-19-106_com.android.chrome.jpg (59.67 KiB) Viewed 168 times
- Screenshot_2024-05-09-12-00-11-422_com.android.chrome.jpg (72.92 KiB) Viewed 168 times
