Hi,
Ive got a 2015 2.0 e89 that is loosing coolant but there's no obvious signs of a leak. About once a month I get the low coolant warning and it takes about 1.5l to bring the float needle in the header tank back up. So it is using or loosing it somewhere I can't find. Has anyone lese had this issue and knows the source/cure.
Coolant loss
- Rucky
Coolant loss
Can only speak for N52 - I had a similar problem. It was dripping from underneath the top hose directly onto the serpentine belt which effectively flung the coolant out so there was no hard evidence of a drip until the leak developed and the belt came off!!
There was the evidence in the belly pan but it was still a job to trace the leak - had to use a torch and mirror to get under the top hose.
04 2.5i Titan silver - 1st Z4 now sold on
07 3.0si Silver Grey M Sport pak.
X5 and assorted motorbikes
- Trav
Coolant loss
You can buy UV dye and torch kits for about 12 quid or so off ebay. Might be worth a try.
Z4MR A.W.
