03 2.5 not starting
03 2.5 not starting
Hi lads
Went out this morning and car wouldn’t start, threw up the following codes
P0160
P0162
P2272
Would I be right in saying o2 sensor and I’m oxo .anyone else have this issue please
P0160
P0162
P2272
2003 2.5 silvery goldish
gaptech,19" ispiris,iPod kit,xcite halos,load of petrol
Onlinesrhutch
- Moderator
03 2.5 not starting
Is it turning over?
Are the ignition lights on?
I don’t think an O2 sensor will stop the car from starting. Could easily be the ignition switch, but as said other than not starting what can you tell us?
- ph001
03 2.5 not starting
Agreed, all those codes are O2 sensor related which aren't used at startup. If not turning over it eill be either starter motor (give it a tap with a wooden mallet) or the ignition switch.
03 2.5 not starting
Car is spinning over fine , started for a sec this morning lumpy and then died , when turned over now it gives a slight splutter but no start
Is the ignition switch a known fault ???
Easy fix ???
Easy fix ???
- ph001
03 2.5 not starting
No, if it's turning over ok it's not likely to be either of those. I'm assuming you have enough fuel in, in which case fuel pump / fuel pressure related maybe. When did you last fill up?
When you switch the ignition on, can you hear the fuel pump priming as normal?
03 2.5 not starting
Didn’t check pump yet . Thought the obd codes would do the hard work for me lol
03 2.5 not starting
Is it an in tank or external
03 2.5 not starting
Tried turning on and off the ignition to check the switch and lights lite up everytime, sounds like the switch may be all right
Focusing on pump now , can you get at wiring in car to check for power , don’t hear it priming but can’t ever remember hearing it
I’ll jack it and have a look now
03 2.5 not starting
We can do better than this!
Accelerator pedal to the floor, hold it there, and crank engine. If it fires, let throttle go. Its a quick clear flood. Repeat once or twice.
If youve got any carb cleaner or wd40 or easy start, pop air cleaner lid off and squirt any of the above in while someone cranks. If it tries to fire, you have a fuel issue. If not, most likely spark.
Quick and dirty checks as a start.
Andy.
Andy.
03 2.5 not starting
Tks for taking the time to answer
I’ll try that
I’ll try that
03 2.5 not starting
Andy
You are THE MAN
Tks a lot , very easy fix when you know how , soun started on full throttle and started straight away with air box open
Wonder what caused it , never failed before
You are THE MAN
- Smartbear
03 2.5 not starting
Good to hear it’s running, when did it last have new plugs?
e85 3.0si sold
03 2.5 not starting
15k in my ownership
- Smartbear
03 2.5 not starting
How about previous to your ownership?
e85 3.0si sold
03 2.5 not starting
I was told Serviced before I bought but could be bull ,
