What is this thingy
- NickDE
What is this thingy
Whilst grovelling around in the passenger footwell installing Cruise Control wiring I found this thing connected to the wiring but hanging loose behind the trim below the glovebox. Does any one know what it is ?
Darkness gone, go Darknes2, go Frozen, go Tronic
- Smartbear
What is this thingy
Doesn't look oem, maybe a tracker or a flux capacitor?
e85 3.0si sold
What is this thingy
Looks like the foo foo valve
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Young Pretender
What is this thingy
Saftval GPS tracker.. according to google
Ever get the feeling you are being watched
- NickDE
What is this thingy
Now that would be nice. How do I control the TTS (Time Travel System) ? I couldn't find any settings for this in Carly
- NickDE
What is this thingy
The current status of the Foofoo Valve is impressive and forward-looking: an atomic-powered version is planned to be carried on the 2016 Dream Chaser shuttle flight from Kennedy Space Center. One of the flight crew, Payload Specialist Gorge Foosamos, will be responsible for the maintenance and deployment of this wonder of modern science, in the hopes that all mankind will benefit from having this extraterrestrial Foofoo Valve orbiting the Earth.
What is this thingy
NickDE wrote: ↑Sat May 20, 2017 12:01 amThe current status of the Foofoo Valve is impressive and forward-looking: an atomic-powered version is planned to be carried on the 2016 Dream Chaser shuttle flight from Kennedy Space Center. One of the flight crew, Payload Specialist Gorge Foosamos, will be responsible for the maintenance and deployment of this wonder of modern science, in the hopes that all mankind will benefit from having this extraterrestrial Foofoo Valve orbiting the Earth.
Can I have what your drinking
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- NickDE
What is this thingy
Now that is scary. Who is tracking me ?Young Pretender wrote: ↑Fri May 19, 2017 11:55 pm Saftval GPS tracker.. according to google
I'm guessing that removing this thingy may be more hassle than it is worth. I assume it is wired in in such a way that just cutting it out will cause something to break,
- NickDE
What is this thingy
Sure, I just e-mailed you a glass.
- Stuartt
What is this thingy
IRC it will have three wires, live, earth and an antennae your best option if you want to remove it is to trace the wires and disconnect them where they tap into the wiring harness. Don't just chop through them.NickDE wrote: ↑Sat May 20, 2017 12:09 amNow that is scary. Who is tracking me ?Young Pretender wrote: ↑Fri May 19, 2017 11:55 pm Saftval GPS tracker.. according to google
If it looks any harder than that just tuck it back up and forget about it. Believe me if no one is paying the subscription they are no longer monitoring it.
Hope this helps
Stuart
2004 3.0i SE Roadster , GONE to a good home
2010 e89 35i Sdrive M sport. GONE for salvage but has been reborn
2014 e89 35is M-Sport Design Pure Traction
What is this thingy
Like he says, nobody paying = nobody tracking. On the other hand it could be useful if you can find out who to subscribe to if you want use itStuartt wrote: ↑Sat May 20, 2017 6:37 amIRC it will have three wires, live, earth and an antennae your best option if you want to remove it is to trace the wires and disconnect them where they tap into the wiring harness. Don't just chop through them.NickDE wrote: ↑Sat May 20, 2017 12:09 amNow that is scary. Who is tracking me ?Young Pretender wrote: ↑Fri May 19, 2017 11:55 pm Saftval GPS tracker.. according to google
Hope this helps
Stuart
- Young Pretender
- Steve84N
What is this thingy
You need the hyper space upgrade for that. Waste of money, they put the button in the boot! You press it, car zaps off to a different dimension, leaving you stranded. - maybe it was intended for kidnap victims.
- NickDE
What is this thingy
Thanks for all the input. I had another look at the wiring and although not too complicated I decided I couldn't be arsed taking it out, so it has been tucked away safely again. And maybe it will function as a Flux Capacitor in the future !
