Jack the car up and place both front corners on axle stands so that you can crawl under. BE SAFE!
Remove the plastic engine tray 7 x 8mm heads
Remove Air Con Belt using a T55 male spline on tensioner. Its spring loaded and needs a small amount of force to move the tensioner idler (see photo)
Next the power drive belt. First draw a picture of the route of the belt as its fairly complicated and having fallen into this trap before with other engines I always draw the belt route now.
The tensioner pulley is fairly difficult to access as it is mid way up the front of the engine. You need a 16mm socket. I used a deep socket hex type not multi hex as the tensioner is quite hard to move and its easy to slip. Tensioner releases in an clockwise direction. (looking at front of car) Ease the belt off when tension is released.
Second picture is with the belt removed and is from beneath the engine (alternator on the LHS of the picture)
Replacement is the reverse of the above. Make sure the belts are sitting correctly on the multi V before releasing the tensioners in each case.
Straight forward DIY job.
As you can see my power belt was fairly badly cracked. Might of been the original! and yes my engine was rusty and oxidised (2003) I tidied up a bit after belts were changed.
3.0L SE Air Con & Power belt replacement
- Toe-side
Before: 2003 3.0 Roadster, Porsche Boxster 987S Now 981S
Success breeds complacency. Complacency breeds failure. Only the paranoid survive
Re: 3.0L SE Air Con & Power belt replacement
These excellent instructions are also applicable to the 2.5. Changed both my belts today no problem although it was a bit fiddly getting the new belt on. The drive belt was very cracked although dont think it was likely to fail very soon. Car has covered 55000 miles with full service history but fairly obvious belt has not previously been changed in 10 years.
I would recommend you check your belts and renew - not that expensive from BMW - £30 for drive belt and £18 for aircon belt.
Thank you for doing this "how to". It made the job so much easier, although it was still awkward. Good tip about drawing the belt path, as no matter how much you think you'll remember, its still confusing re-routing the belt.
__________
2003 Z4 3.0i, titan silver with black leather, DLV exhaust, Royal steering wheel retrim.
