Hi all,
Changing the rear bushes and drop link this evening after developing a knocking, any tips? do both wheels need to be off the ground to release tension in order to remove the who anti roll bar?
Rear anti roll bar bushes and drop links
- kammy1975
Have developed a knocking from the rear since lowering the car, and when having the car alignment done today, the mechanic pointed out the rear stabiliser drop link was done for. Said it was worth changing the anti roll bar bushes too, so did you manage to do this ? As you mentioned, does the car wheels need to be off the ground for suspension to be unloaded ?
