My 2006 M Roadster is getting an oil change and I didn't get a manual with the car so I'm looking for a spec sheet with the fluid capacities .... if anyone has a scanned or digital version it would be greatly appreciated.
Got a few niggly things to fix to get it up to snuff and I thought it might like some fresh oil so I can have a baseline for the future.
and...Can't find a proper Manual for the life of me, any good links or tips on where I might find one ??? (Don't suggest looking in the glove box )
Need a spec sheet for my S54. Capacities etc
- mcbeee
Sold the Z4 M Roadster and a 911 Carrera S now I have a 2021 Z4 3.0i
Online
I can scan the relevant pages from my book when I get home.
If it was in the pack with all the other books, then there's no way It would fit in the glovebox anyway, so mine stays at home.
For now you should be able to download the user manuals from this link (just find the M version and you'll be taken to a location to download a zipped file).
- Fishy Dave
Hello,
You can still order new paper manuals through your dealer:
Z4 General: http://www.realoem.com/bmw/enUS/showpar ... Id=01_0210
M supplement: http://www.realoem.com/bmw/enUS/showpar ... Id=01_0709
A guide like this might help? http://www.billswebspace.com/Z4MS54OilChange.htm
It's hard to give an exact volume (to the ml) as it will vary slightly depending on whether the car is flat or at an angle when you are draining the oil. Try 5.5 litres, start the engine for a bit, switch off and re-read adding as necessary.
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
Mazda RX-8 race car
That's how you do it, but it would be best to start with 5L and see where it's at.Fishy Dave wrote: ↑Sun Jul 30, 2017 9:17 am Try 5.5 litres, start the engine for a bit, switch off and re-read adding as necessary.
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
- mcbeee
Thanks Guys,
Finally got the right links, found all the info I need. Excellent.
- srhutch
- Moderator
If you need PDF's of the Z4 manual and ///M one let me know.
- mcbeee
Got the PDF's, made the laser printer work overtime... selected pages only, not the ones that tell you how to drive or how to put the key in the ignition. Thanks.
